Author Topic: How do you refinish carb linkage parts?  (Read 2090 times)
Offline Seadog
« on: August 17, 2015, 10:54:38 PM »
I'm rebuilding my 2100 carb.  The various parts on the outside of the carb, like linkage pieces for the choke and throttle, have a lot of oxidation and even a little rust.  What's the best way to restore these parts?
Thanks for your help!
Re: How do you refinish carb linkage parts?
« Reply #1 on: August 18, 2015, 02:16:32 PM »
Remove, clean and replate
Often there are multiple finishes - some that can be done at home while others are better shipped to a service. Problem is that there are only a few "bits" in total so the minimum cost for plating will be much higher (in most cases) per item than if you get allot of pieces plated at the same time.
If you go the rattle can fake plating it will be noticeable IMHO
Offline Seadog
« Reply #2 on: August 18, 2015, 09:35:11 PM »
Thanks for the info.  Yes, I agree about the rattle can.  I would rather leave as is than take that path.
Offline markb0729
  • South Jersey
« Reply #3 on: August 18, 2015, 10:32:58 PM »
If you are not up to the task you can have it rebuilt and replated.  This fellow seems to get decent reviews.  I've never used him so be sure to do your homework, search the forums and give him a call if interested.  He's charging $165 to do a Autolite 2100.
KP Carbs direct:
http://www.kpcarbs.net/home.html
KP Carbs eBay store:
http://www.ebay.com/itm/Ford-Autolite-2100-2150-carburetor-restoration-service-/151783657258?hash=item235702cf2a
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
« Reply #4 on: August 28, 2015, 04:51:15 PM »
Most shops today will just plate all the linkage dichromate so expect to disassemble some of it when it returns so you can refinish what is needed correctly.
Just to much of a hassle for the shops I guess and not enough owners notice or know any differently. Everything is clean and pretty  ::)
Offline markb0729
  • South Jersey
« Reply #5 on: August 29, 2015, 07:40:57 PM »
Good info.  Sounds like a question to ask KP Carbs.
