Author Topic: Washer bag position  (Read 2170 times)
Offline 66RavenGTCoupe
Washer bag position
« on: August 16, 2015, 12:46:29 AM »
Hi all,
Was the washer bag in the same position on all 64 1/2 to 66's?
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Offline petersixtfive
Re: Washer bag position
« Reply #2 on: August 17, 2015, 12:26:37 AM »
Hi all,
Short answer - No
And remember not all were installed at the factory, which helped contribute to the answer above :)
« Reply #3 on: August 18, 2015, 11:46:41 PM »
Thanks guys.
So were there two washer bag bracket sizes? If so which one and what placement would be correct for a Sept 64 SJ car please? Any pics Jeff?
« Last Edit: August 19, 2015, 06:54:55 PM by 66RavenGTCoupe »
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #4 on: August 19, 2015, 04:01:44 PM »
Thanks guys.
From my notes, the same bag bracket (B9BA-17651-A) was used for 1964 and 65, it changed in 1966 (C6OB-177651-A). The difference I believe, is the 64-65 has two mounting holes, the 66 has a third in the between the two, function possibly for welding, or alignment.
« Last Edit: August 19, 2015, 07:39:08 PM by jwc66k »
« Reply #5 on: August 19, 2015, 06:59:12 PM »
Thanks JWC66K
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #6 on: August 19, 2015, 07:57:57 PM »
The dealer installed version was a different size than what was typically installed at the plants. Just another variation in the pattern
Of course dealer installed will effect the possible placement also
« Reply #7 on: August 19, 2015, 08:03:09 PM »
Interesting twist. Thanks Jeff.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
