Author Topic: Wheel lugnut torque specs  (Read 10450 times)
Offline MattDoscher
« on: August 14, 2015, 10:36:54 AM »
I was looking through my '65 Comet, Falcon, Fairlane and Mustang shop manual recently and noticed the lug nut torque specs are pretty much the same across the board.  I'm pretty sure I was reading it right.  Doesn't it seem funny that a 6cyl Comet would have the same torque specs as a 8cyl Mustang?  It looks like my '65 C code Mustang w/ styled steel wheels and my wife's '65 6cyl Comet w/ steel wheels and hubcaps both have 90 FT LBS lug nut torque specs.
Matt Doscher
5H25T582252
Re: Wheel lugnut torque specs
« Reply #1 on: August 14, 2015, 10:38:34 AM »
not strange at all. the studs & nuts are the same size which is what i believe torque values are based on.
Offline WT8095
  • Dave Z.
« Reply #2 on: August 14, 2015, 10:44:36 AM »
+1. Material, thread style & pitch are also factors, but it comes down to an ideal torque for a given fastener combination. The application and number of fasteners are not relevant - those affect which fasteners are used.
Dave Z.
Offline Toploader
« Reply #3 on: August 14, 2015, 03:05:22 PM »
This number didn't feel familiar to me. So I checked, and my manual says 75 - 110 ft. lbs. for V8, and 55 - 85 ft. lbs. for six cylinders.
76A-Y-D2-13H-72-6-6
Offline MattDoscher
« Reply #4 on: August 14, 2015, 10:55:25 PM »
I'm comparing my C code '65 Mustang to my wife's 6cyl '65 Comet and in the shop manual on pg 3-49 lists both 6cyl and V8 Comets as having the same torque specs (75-110) as the V8 Mustangs.  Just seems weird, 4 lug compared to 5 lug and different wheel and lug nut combinations (acorn vs regular nuts) but I understand the same size studs and nuts so I guess that is what it really boils down to.
I would think a heavier Comet convertible 6cyl w/ 4 lug wheels would have different specs compared to a lighter V8 Mustang w/ 5 lug styled steel wheels.  But I guess that's maybe the reason for the wide (75-110) spec in the shop manual.
Matt
Matt Doscher
5H25T582252
Offline Smokey 15
« Reply #5 on: August 15, 2015, 03:58:39 PM »
 I thought you tightened them to just before breaking them off.
/\/\/\ Exactly. I set my torque wrench to 100lbs. on all 1/2 & 5/8" wheel studs.
Offline Toploader
« Reply #6 on: August 15, 2015, 04:30:22 PM »
Matt, if you check page 3-46 the 55 - 85 spec is also listed for 6 cyl. Comets (front). The number on page 3-49 could be a typo.
76A-Y-D2-13H-72-6-6
Offline MattDoscher
« Reply #7 on: August 16, 2015, 09:52:08 AM »
Quote
Yeah I see what you mean.  Funny it doesn't mention the rear at all!  Thanks All!
Matt
Matt Doscher
5H25T582252
