Author Topic: Shift Lever  (Read 1894 times)
Offline sparky65
Shift Lever
« on: May 14, 2010, 11:14:47 PM »
Another chrome part this is for a 67 with auto console.  The lever just has light surface rust so it seems like a good re-chrome candidate.  Once again more moving parts.  I didn't pull the T handle but somehow this looks like it could be a problem part for re-chroming.  The reproductions are only available as a complete set.  May not be a bad idea considering the whole thing needs to be cleaned or plated but how good are these repros?
Steve
2009 Black GT Coupe
Offline Sunlitgold68
Re: Shift Lever
« Reply #1 on: May 15, 2010, 12:32:15 AM »
You can get the shifter and T handle rechromed for a reasonable amount and will look far better than a reproduction. Place I used took the wire mechanism out and put it back for me so you won't have to do that.
8T01C204XXX
Built May 14th, 1968
Offline sparky65
Re: Shift Lever
« Reply #2 on: May 21, 2010, 10:09:31 PM »
If you don't mind how much did it cost to get them re-chromed?  I took mine all apart today.  It actually is pretty easy to get apart.  The trick is remembering how it all goes back together.
Steve
2009 Black GT Coupe
Re: Shift Lever
« Reply #3 on: May 21, 2010, 10:34:40 PM »
It cost me $90 to replate the shaft.
I didn't rechrome my T handle because I wanted something original and untouched and thought that was a good piece to leave alone.
8T01C204XXX
