Author Topic: '65 grille hardware  (Read 2887 times)
Offline tvor
'65 grille hardware
« on: August 12, 2015, 04:37:48 PM »
can someone please tell me what hardware goes in these two holes?  I've searched all thru the hardware spreadsheet, even doing a search for 'grille' and 'support', but the only hardware that comes up is either 5/16x18 or 10-12.
BTW, the hole diameter is 17/64"
Thank you,
Kelley
'65 Coupe, built in San Jose.
289 CID with C4 trans.
Door plate date of 9/11/64
Original owner - mom
Second owner - me!
Re: '65 grille hardware
« Reply #1 on: August 12, 2015, 06:50:01 PM »
Same as the other 6 hex screws on the grille.  There should be 2 slide clips on the grille for the screws to attach.
« Reply #2 on: August 12, 2015, 08:27:34 PM »
Not quite. They are the same screws but are a different finish, 42127-S2 (phosphate and oil). The description used in the spread sheet is "GRILLE PONY/CORRAL SUPPORT-GRILLE CENTER", although Ford called the item (C4ZB-8194) "Retainer - Radiator Grille Ornament". I set up the hardware nomenclature to consolidate a group of parts such as everything associated with the grille will use the first word "GRILLE".
Offline rodster
« Reply #3 on: August 13, 2015, 12:16:02 AM »
Original example.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #4 on: August 13, 2015, 12:21:51 AM »
What are the head markings?
Offline rodster
« Reply #5 on: August 13, 2015, 12:28:36 AM »
I think 'D' but will have to double check tomorrow.
1984 SVO - 2A
Offline ChrisV289
« Reply #6 on: August 13, 2015, 01:58:12 AM »
I thought the head marking was CF
2009 V6 Mustang Coupe
« Reply #7 on: August 13, 2015, 10:03:54 AM »
CF was typical on San Jose cars.  'D' or plain seen on Dearborn/Metuchen.
The plating sometimes match the other grille attaching screws, sometimes they don't.
« Last Edit: August 13, 2015, 11:35:40 AM by caspian65 »
Offline tvor
« Reply #8 on: August 13, 2015, 12:53:41 PM »
Whadayaknow....  I thought for sure that those two holes were too big for the 10-12 screw, but I guess it does work!  I thought for sure that it would be closer to a ΒΌ-20 screw with a recessed hex head.
Thank you Rodster for the pic.
BTW, my head markings are CF
Guess I'll finish up the grill today  :).  Thanks everyone!
Second owner - me!
« Reply #9 on: August 13, 2015, 04:02:48 PM »
Thanks. I've updated the spreadsheet to reflect the "CF" head for a San Jose application. There's only so much room on the spreadsheet for detailed information.
If you haven't considered getting a set of the Osborn Mustang Assembly Manuals for your year Mustang, you should.
Offline rodster
« Reply #10 on: August 13, 2015, 10:15:43 PM »
'D' it is.  ;)
1984 SVO - 2A
