Author Topic: Kelsey Hayes or Bendix - 69 GT350  (Read 1726 times)
Offline ddonzella
« on: August 11, 2015, 05:23:02 PM »
June 12, 69 gt350. Is the rear brake backing plate supposed to be Bendix or kelsey hayes?
« Last Edit: August 16, 2015, 11:23:51 PM by J_Speegle »
Offline ddonzella
Re: Kelsey Hayes or Bendix
« Reply #1 on: August 11, 2015, 05:23:58 PM »
Sorry! Dearborn!
« Reply #2 on: August 11, 2015, 06:31:08 PM »
Typically they were Bendix. less typical KH . I have actually seen one side Bendix and one side KH more times then I have seen both sides KH.FYI be sure to use the correct KH backing plate plug (cross hatch texture ) or the Bendix (starts with 8A) plug depending on plate.
Offline ddonzella
« Reply #3 on: August 11, 2015, 10:02:18 PM »
ok! Thank You
Offline Aussiemach
  • Silver Level Subscriber
« Reply #4 on: August 11, 2015, 11:20:56 PM »
Thanks Bob for the info, my 69 Mach1 is as you describe
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Offline TLea
« Reply #5 on: August 15, 2015, 10:39:27 AM »
+1. In addition to different adjuster lug there is also a difference in wheel cylinder attaching bolt
