I just got done doing my 70 B302 in Grabber blue and its a single stage in DCC acrylic urethane paint and if u really want that super deep look , you can also clear coat it. You can color sand & buff out single stage if desired.
Using a solid color I would use single stage as others have stated, its easier to blend if needded on a repair ( yes it takes an experienced painter) the 2 stage water paint base is junk- the reason they use the water base paint as its super easy to blend paint.
Look at all these cars on the road that have clear coat coming off on the roof line, 1/4, deck lids, hoods etc they all are 2 stage water based paint.
PPG makes a very good product and in acrylic or enamel base paints with the correct hardners.
Below is pics of my 70 B302
