Author Topic: Driveshaft Markings - 67 390 w/C6  (Read 2571 times)
Offline V8_bloke_28
« on: August 09, 2015, 02:23:25 AM »
Hi. I'm trying to find the colour/amount the stripes should be on my driveshaft.
The car is a San Jose June 67 built gta mustang fastback. C6 auto with 390 v8.
Car has ps and ac with 3:00 conventional diff. I haven't got a build sheet and I can't find anything that matches my car. All I know is it should be bare metal.
Cheers
« Last Edit: August 09, 2015, 04:35:54 AM by J_Speegle »
Re: Driveshaft Markings - 67 390 w/C6
« Reply #1 on: August 09, 2015, 04:37:19 AM »
Unfortunately 67 buildsheets didn't show driveshaft markings - that started in 68 :(
Believe they might be the same as 67 GT500 with an automatic
Will try and confirm and post
Offline V8_bloke_28
« Reply #2 on: August 11, 2015, 07:37:49 AM »
Any luck?
« Reply #3 on: August 11, 2015, 04:48:26 PM »
So that you understand the logic I'm trying to apply here I offer the following
- I have pictures of original GT500 automatic drivelines
- Don't have any information on buildsheets for this detail
- Have no original 67 390 automatic drivelines to show at the moment
- On paper 67 GT500 with automatics were ordered as 390 fastbacks with certain parts replaced/substitued on paper so that they would get the final product they were wanting. If the part is not listed on one of these lists it can be assumed that the part was not replaced and the piece is the same as used on the 67 390 car. Looking at the Shelby add delete I could find none of the automatic car orders showing that the driveline was replaced as it was listed for 4 speed cars. It was the same piece yet the markings were different. Those were assembled (like all Mustangs) at another plant and arrived ready to install as a unit
So following that I offer the following as found on 67 GT500's with automatic. My best guess at this point. Of course you can choose to hold off until you have more information. You should not (if shown in a Concours Restored class) loss any points for not having the marks and they are very easy to add later
Stripes from front to rear normally
True Red - Medium Blue - Strong White
Offline Paperback Writer
« Reply #4 on: August 11, 2015, 05:23:57 PM »
Here's what I found on my San Jose '67 390 C6.  The only caveat is that my car was built in September 1966, so things could have changed by June 1967...
1967 390 GTA Convertible
7R03S110###
« Reply #5 on: August 11, 2015, 05:43:44 PM »
Nice graphic :)
Looks like yours are in reverse to the ones I have - not that unusual or sometimes they get reinstalled (after replacing the U joints) backwards at some point.
Can confirm that the three identification stripes continued through approx Mid Feb 67
The one I have pictures of had a sea foam green and another inspector or makers mark/stripe at each end - unrelated to the identification stripes
« Reply #6 on: August 11, 2015, 05:44:14 PM »
Thanks Jeff!
Here are some additional documentation photos of the original drive shaft from my car.
And yes, there was a sea foam green inspectors mark on the differential end of mine too (see the last photo)...
« Last Edit: August 11, 2015, 06:33:29 PM by Paperback Writer »
7R03S110###
« Reply #7 on: August 11, 2015, 10:01:37 PM »
On my example the sea foam was a stripe around the driveline - the rear yoke had a different colored swipe
Offline V8_bloke_28
« Reply #8 on: August 13, 2015, 04:09:47 AM »
Thanks guys.
Appreciate it.
