Author Topic: C-4 Neutral Safety switch wiring  (Read 1228 times)
Offline C5ZZ
« on: August 06, 2015, 10:07:40 PM »
Looking for the correct routing and how the wiring is fastened to the firewall
for the neutral safety switch wiring harness that goes up the firewall and plugs
in toward the top. It's a 65 6cyl Dearborn built 10/64. Pictures would be great!
Thanks!
MCA # 00945
Rangoon Red/Red Interior
Offline goumoun
Re: C-4 Neutral Safety switch wiring
« Reply #1 on: August 11, 2015, 08:24:08 AM »
Unrestored 65 Mustang coupe scheduled build date Dec 15 1964 Dearborn for Export, the one in my avatar:
65A  K  25  15M  91  1  6
5F07A372xxx
Offline C5ZZ
« Reply #2 on: August 11, 2015, 09:04:24 PM »
Thanks for the picture.
Do you know where else the harness was fastened?
My understanding is that a clip was used on a bellhousing bolt
but would like to confirm.
MCA # 00945
Offline Richard P.
« Reply #3 on: August 11, 2015, 09:55:02 PM »
I think that there was a clip on the low/reverse servo that holds the wire.
Offline goumoun
« Reply #4 on: August 12, 2015, 04:41:08 AM »
Yes same. The clip is attached to the upper left bolt at the rear servo. Nothing else as far as I know.
65A  K  25  15M  91  1  6
5F07A372xxx
Offline C5ZZ
« Reply #5 on: August 12, 2015, 11:55:22 PM »
Thanks, I know of the clip on the servo cover but its a long distance
from there to where it plugs in at the firewall, seems like there should
be something else to hold the harness.
MCA # 00945
Offline goumoun
« Reply #6 on: August 13, 2015, 07:58:42 AM »
So true, this is disturbing but there was nothing.
65A  K  25  15M  91  1  6
5F07A372xxx
Offline C5ZZ
« Reply #7 on: August 13, 2015, 02:34:45 PM »
Ok, thanks so much for checking!
MCA # 00945
