Author Topic: Drip Rail Foam  (Read 1656 times)
Offline Sunlitgold68
Drip Rail Foam
« on: May 13, 2010, 03:21:41 PM »
Looked over my metal drip rails and there appears to be some type of foam maybe 1 inch wide and 1 mm thick adhered to them. This appears to be some form of a buffer between the drip rail and the roof. Can this foam piece be bought somewhere?
8T01C204XXX
Built May 14th, 1968
Re: Drip Rail Foam
« Reply #1 on: May 13, 2010, 09:44:00 PM »
There are a number of companies that can supply this - have seen 3M and other lesser known companies. Can be kind of expensive, considering that you have to purchase 50+ feet in a roll
Some have chosen to use the narrower product and lay two strips side by side
1967 eight barrel
  • Guest
Re: Drip Rail Foam
« Reply #2 on: March 12, 2015, 12:06:44 PM »
I found the exact product, and it's about eight dollars for enough to do a 67-8 fastback (12'). It's correct color, thickness and adhesive foam. Is is about a 1/16"of an inch wider than the original material removed. About 1/8 thick.
The label was in a clear bag. It has three running horses printed below the information.
Fits: 1983-93 Mustang Convertible. Top W/S retainer channel to frame seal.
&81-88 Mustang T-top w/s retainer channel to body seal.
#D338 Replaces: E3ZZ-7624484
If anyone needs a picture of the label and the material, advise.  I will post.
