Author Topic: Windshield washer reservoir  (Read 1536 times)
Offline preaction
« on: August 03, 2015, 08:32:37 PM »
Any tips on techniques for taking  ford reservoir from  yellowed to a cleaner shade of white.
Re: Windshield washer reservoir
« Reply #1 on: August 03, 2015, 09:18:50 PM »
Offline suskeenwiske
  • 214-347-3628
« Reply #2 on: August 03, 2015, 09:26:29 PM »
Is it surface yellow or all the way through? If all the way through, I'm not aware of any process that will reverse it.
I've not tried this but possibly the polish used to restore plastic headlight lenses will work; only if it's surface yellow though. Try an inconspicuous as possible spot first. A mildly abrasive tooth paste on a damp rag may be another possibility. I have some other ideas but they may be harmful, so better not share those.
Hopefully someone else has had experience with this and will share.
Good luck...Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
  • 214-347-3628
« Reply #3 on: August 03, 2015, 09:32:52 PM »
P.S. - Don't use bleaching chemicals, peroxides or paint or lacquer thinners, it'll break down the plastic. Slow and steady is best whatever way is the most effective and don't place it in the sun, the plastic will become brittle.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
