Author Topic: door wire harness  (Read 6783 times)
door wire harness
« on: August 03, 2015, 09:21:26 AM »
Have you used anything with success to replace a broken/cracked wire sleeve that protects the wires in the area between the body and the door?  If so, what material did you use? See pic for what I'm talking about.  Thanks
Re: door wire harness
« Reply #1 on: August 03, 2015, 09:38:03 AM »
Yeah...repro harnesses made by Alloy Metal...I have replaced mine with a set and they look very nice.
« Reply #2 on: August 03, 2015, 10:57:11 AM »
+1 .. The tube is heat sealed in the two plugs . It is difficult to clear the plugs for a new sleeve. The wires have to be cut to slid a new sleeve on and respliced . The repair can be done but the time and effort is not worth it what with the nominal price of the nice looking reproduction part  IMO.
« Reply #3 on: August 03, 2015, 11:02:00 AM »
Thanks Richard and Bob
« Reply #4 on: August 04, 2015, 01:35:14 AM »
Yes have cut one of the plugs off - slipped the assy off the wires. Replaced the sleeve/tube and reassembled then affixed the sleeve to the plugs once again once everything is back in its place,
Does leave a repair inside the door where it can't be seen
Very little I will not try and fix - except automatic transmissions :)
« Reply #5 on: August 04, 2015, 06:29:07 AM »
Jeff, where did you get the sleeve from?
« Reply #6 on: August 04, 2015, 05:41:28 PM »
One time I found some plastic tubing (thin wall) at a local electronic store (Fry's)  and another time I used shrink tubing but didn't heat it ;)
« Reply #7 on: August 04, 2015, 06:00:35 PM »
That is what I did but in the case of the heat shrink I played around with different sizes and picked the one that was closest diameter once heat shrunk. I would pre shrink the hose first then use it with the plugs. Like I said before a lot of time and work compared to the reproduced harness and its nominal cost. Heck you will end up with a non original hose (only visible part) regardless of which directon you choose to proceed. It depends on which way makes the best sense to the individual. Everyone is different .
« Reply #8 on: August 04, 2015, 06:06:38 PM »
........It depends on which way makes the best sense to the individual. Everyone is different .
+1   Doesn't always make sense (in dollars and time spent) while some will find the pleasure of doing things themselves or overcoming the challenges. To many achieving this can be  priceless.
Sometimes the benefit is just finishing what you started on your own. ;)
« Last Edit: August 04, 2015, 06:08:53 PM by J_Speegle »
« Reply #9 on: August 04, 2015, 06:26:12 PM »
+1 I don't "do" what I "do" on my car for you, I "do" what I "do" on my car for me. I prefer to work to a standard in any case. Today's activities were not automotive related, but I enjoyed what I did just the same.
« Reply #10 on: August 07, 2015, 08:34:59 AM »
Ok so I obviously fall into the category of trying to fix it.  That is enjoyable to me.
I did find that heat shrink tubing is a bit too rigid, even compared to the old stuff that had hardened.  Then I went into my stash of wiring bits and pieces, and found part of a harness from some unknown vehicle and year.  Turns out to be the exact same tubing, in terms of color, diameter, etc.
The first picture shows the donor harness, with wiring removed from the tubing.  The second picture shows the tubing being bent, and a piece of heat shrink tubing (green tape on end) that does not like to be bent so much.
Since one wire from each door was cracked at the flex point, I decided to cut there.  Picture three shows the type of wire used.  The broken wires were of the 0.013" diameter strand variety.  Note that this is an interior décor with convenience control option, no door speakers.
I did an inline splice on each wire on both sides of the large rubber plugs.  The donor wire used was all the finer strand (0.010" dia) so as to be more flex friendly.
As Bob noted, the large rubber plugs were attached to the old tubing (glued perhaps), and I glued the replacement tubing in place.
Offline WT8095
  • Dave Z.
« Reply #11 on: August 07, 2015, 10:17:37 AM »
67gta289, what is the ouside diameter of the tubing? Do you have a caliper or micrometer to measure wall thickness?
Dave Z.
« Reply #12 on: August 07, 2015, 10:27:48 AM »
I don't know...yes I do...and I will!
« Reply #13 on: August 07, 2015, 12:30:09 PM »
A word of caution about the condition of the copper wire you would be re-using should you go ahead and rebuild your originals. They get weak with age and if the outer sleeve has already broke, prone to a short life at the location of the broken sleeve. Every time the door gets opened/closed...in repetition of a few thousnd times, the copper simply breaks in two. A FIRM tug-test would be in order plus a good continuity test with an ohm meter.This is one of those areas to choose, is it work $40x2 to simply be DONE? My vote is YES!
« Reply #14 on: August 07, 2015, 02:02:57 PM »
Richard, I agree, which is why I replaced all of the wires in the flex zone, not just the broken one.  Continuity test done as well.
