Author Topic: restoring spare tire jack  (Read 3493 times)
Offline Sunlitgold68
« on: May 13, 2010, 01:14:00 PM »
Did Ford paint the whole spare tire jack with the spiral part and large bolt part installed or separate? Is that part suppose to be painted black along with the jack?
8T01C204XXX
Built May 14th, 1968
Re: restoring spare tire jack
« Reply #1 on: May 13, 2010, 01:54:22 PM »
The jack was not painted black as an assembled unit.  I have some pictures of some originals at home.
« Reply #2 on: May 13, 2010, 02:03:29 PM »
Can you get the bolt and spiral part off? Is that how people restore them and then reinstall?
8T01C204XXX
Offline 67shelby
  • Just jackin' around
« Reply #3 on: May 13, 2010, 03:29:59 PM »
Charles, can you send my your original pics?  I need some for my jack article....
Lorne Willard - MCA 38287
1965 GT Coupe, 1966 Convertible, 1967 Shelby GT350, 1968 Coupe, 1970 SCJ Mach 1,2003 Mach 1, 2007 Shelby, 2013 GT Vert
MCA Certified: 65-66 Concours, 67-68 Concours, 69-70 Concours, 71-73 Concours, 65-66 Concours Shelby, 67-68 Concours Shelby, 69-70 Concours Shelby, OD, DD
Offline 67shelby
« Reply #4 on: May 13, 2010, 03:31:24 PM »
I think it is possible on some types of jacks to get the spiral or thread out, but you'd have to grind down some stops or remove pins depending on which jack you have.  What year and type do you have?  You'll probably have to post pics...
« Reply #5 on: May 13, 2010, 03:47:27 PM »
It has the stop on it at the end. Standard 68 jack. Would have to grind it down and not sure I want to do that.
8T01C204XXX
Offline 67shelby
« Reply #6 on: May 13, 2010, 04:40:00 PM »
Yea, I'm not sure how you'd recreate it if you did grind it down.
BTW, there are two different 68 jacks.  They changed over in January of 1968, they are different.
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #7 on: May 13, 2010, 04:44:08 PM »
Sunlit...
I surgically ground my 2 tabs off with a thin cutting disc on a dremmel.  The divot where they "staked" it at the factory remained.  Then when I got my screw plated and the frame blasted and painted, I reinstalled the screw and took it to work with me and restaked it in the same spots.  You can't tell it if you don't have a magnifying glass.
66 Metuch Conv
Nightmist, Std Blu Int
Offline 67shelby
« Reply #8 on: May 13, 2010, 04:49:24 PM »
Sunlit...
How'd you restake it?  Just a spot weld?
Offline bryancobb
  • 2009 Ridn' Around
« Reply #9 on: May 13, 2010, 07:06:44 PM »
No..
I work at a steel fabrication company/machine shop.  We are ASME pressure vessel/boiler fabricators.
I used our Piranha Iron Worker and a square piece of tool-steel.
66 Metuch Conv
