Author Topic: Build date vs built-in parts  (Read 2108 times)
Offline camelback
« on: May 11, 2010, 06:05:16 PM »
My 67' coupe was scheduled for build on 05/05/67 at Dearborn, a white 289/C4, nothing special.
The following parts or how the parts are mounted are confusing:
  • fuel line is running at tunnel. I thought fuel lines after above mentioned building date are running at rocker
  • according to the 1967 Chassis Assembly Manual it should have a steering gear/shaft coupler installed, but its not
  • windshield washer reservoir is a plastic container, but the bracket to hang on a bag is still welded at the apron, just the hooks cut away
I'm wondering if someone has changed this items during the years, but to replace the fuel line in a complete different way makes no sense to me....
'67 Coupe Dearborn Scheduled Build May 5th,1967 289/C4
'70 Conv. Dearborn Scheduled Build December 16th,1969 302/C4
'71 T-5 Conv.Dearborn Scheduled Build October 8th,1970 302/C4
MCA #74746
Re: Build date vs built-in parts
« Reply #1 on: May 12, 2010, 04:07:17 AM »
Did you get a Marti report to find out exactly when your car was really built?
That aside yes you car is very late for those features but it would not be unusual for a prior owner to use parts from an earlier car on yours - including the fuel line routing as they may have thought all 67 were equipped the same
Offline camelback
« Reply #2 on: May 12, 2010, 06:06:16 PM »
Yes I have a Marti report:  Order Received: 04/25/67
                                    Serialized:        04/26/67
                                    Scheduled:       05/05/67
                                    Built:               05/05/67
                                    Released:         05/05/67
                                    Sold:               05/10/67
Must be. 43 years is a long story. And the fuel line was changed ones for sure.
Thanks for your help Jeff!
MCA #74746
Offline camelback
« Reply #3 on: May 16, 2010, 05:29:00 AM »
just found a receipt...the apron is a newer replacement...
MCA #74746
