Author Topic: '68 C code Spark Plug Wire Extension Bracket  (Read 1561 times)
Offline Oz390
« on: July 22, 2015, 08:10:43 AM »
Does anyone have a photo of the correct install of the extension that screws to the tab on the valve cover?
C code GT/CS, late April '68 build date.
I think it faces forward, but am not sure, and I am unsure if there is a defined correct installation, as to which side of the tab on the valve cover it attaches to and which way the screws were applied....
Have looked on the webernet for pics, but could not find any that clearly showed this detail.
8R03S : 76A I 2A 15M 72 5 U
Re: '68 C code Spark Plug Wire Extension Bracket
« Reply #1 on: July 22, 2015, 05:57:21 PM »
"points" forward and is painted with the engine
Picture (from sort of below) of one in the library under San Jose - 64-70  section,
Thread  68 San Jose - Engine Installation - 10307-12 First in Series
Here some additional original examples - Well sort of  ::)
Offline Oz390
« Reply #2 on: July 22, 2015, 07:31:31 PM »
Jeff, perfect.
Thank you!
« Reply #3 on: July 22, 2015, 07:39:57 PM »
Ooooh! A WHITE spark plug wire seperator!   :o
« Reply #4 on: July 23, 2015, 12:53:32 AM »
Or just a bad angle for the camera and a reflection - like the top of the valve cover :)
Unfortunately no addition pictures of that detail from this car
But I did find a few examples going through my pictures
« Last Edit: July 23, 2015, 12:57:41 AM by J_Speegle »
