I was asked about the manifold bolts and my research turned up very little information. Pictures do not do much to solve this situation. What is needed is either direct documentation or a direct measurement. On the documentation part, the Osborn manuals do not have this information, my 1975 edition of Ford Car Parts (aka Master Parts Catalog - MPC) book skips over 68 manifold bolts in the manifold illustrated section and the part number section. Other years and similar big block engines are also lacking specific information.
What I am asking is for someone to remove a few intake manifold bolts for big block engines used on Mustangs and measure them: diameter; pitch; overall length; thread length; head markings; location on the manifold; other attributes associated with that bolt, spacer, washer (with dimensions), also used for what accessories.
The same situation applies to the two bolts used for the water outlet on big blocks for the applications listed above (engine, year, etc). I have this much on these two bolts, they may be 358805-S7, 3/8-16X1 1/4 hex split ring lock washer (see pg 36 of AMK Guide to Ford Fasteners) as referenced in the 73-79 Ford truck MPC.
Any information found will be entered in the appropriate Mustang Hardware Spreadsheets for future reference.
