Author Topic: quarter window upper pivot bushing  (Read 3374 times)
Offline kcodecoupe
« on: July 18, 2015, 09:54:18 AM »
looking for a replacement quarter window upper pivot nylon bushing for 69-70 a sports roof car, mine are worn causing the quarter window to be loose at the top pviot point, checked with the vendors and only see the complete window frames availible,
« Last Edit: July 22, 2015, 09:21:03 AM by kcodecoupe »
Offline kcodecoupe
Re: quarter window upper pivot bushing
« Reply #1 on: July 18, 2015, 08:30:26 PM »
I think i found a fix , went to the hardware store and found a small bronze bushing that worked in place of the worn out nylon one. cant be seen after its installed.
« Last Edit: July 19, 2015, 09:24:57 AM by kcodecoupe »
« Reply #2 on: July 18, 2015, 10:33:14 PM »
     Post a picture of what you found and what it looks like installed ?  Thanks, Brian
     Just as I posted the above it occurred to me the bushing goes into the window frame ?
« Reply #3 on: July 19, 2015, 12:48:56 AM »
I think i found a fix , went to the hardware store and found a small brass bushing that worked in place of the worn out nylon one. cant be seen after its installed.
Just for future reference: what store; what type of bushing; used for; made by; part or stock number. If you re-invent the wheel, tell us how.
Offline kcodecoupe
« Reply #4 on: July 19, 2015, 09:24:11 AM »
I installed the glass with the bronze bushing and it worked ,i will take it back out for a picture and give more details ,in short its a smaller version of a door hinge bronze bushing,
Offline WT8095
  • Dave Z.
« Reply #5 on: July 19, 2015, 09:30:41 AM »
Not that it will help, but they do have a part number, C9ZZ 6329848-A. The black square next to the part number in the illustration is linked to a note that reads "supplied only in assembly - group 29706". The assemby being the entire quarter window. Note the contradiction - illustration says not available separately, yet it has its own service part number. Seems like they created a number for it later on and didn't update the note in the illustration.
Dave Z.
« Reply #6 on: July 19, 2015, 03:20:11 PM »
Please include the source of your fix.
Offline kcodecoupe
« Reply #7 on: July 20, 2015, 06:38:46 PM »
The bushing is called a bronze flange bearing from value hardware ,1/4 inch i.d. 3/8 inch o.d. 1/2 inch long,  i removed the worn nylon bushing and hand filed to fit the o.d. of the new bushing to fit the hole in the window frame then used a little two part epoxy, two secure the bushing in the window frame so it wouldnt turn in the frame, i will try to post a picture,
Offline kcodecoupe
« Reply #8 on: July 21, 2015, 06:10:33 PM »
i couldnt get a picture to upload to the post, i can e mail  it to someone if the want to try to post it.
« Reply #9 on: July 21, 2015, 06:19:10 PM »
send it here..  autolite65@gmail.com
Offline kcodecoupe
« Reply #10 on: July 22, 2015, 09:24:29 AM »
  I sent you pictures of the bushing fix,  chuck.
« Reply #11 on: July 22, 2015, 09:34:18 AM »
here are his pics.
