Author Topic: 70 Metuchen Rocker Panel/Rear Blackout  (Read 3443 times)
Offline wjgrnp
« on: July 16, 2015, 10:40:45 PM »
Hi
After a color match with a NOS moulding I am about to reinstall my rocker panel mouldings.
I have read the post from Feb 11 2010 on a 69 Dearborn car.
I would appreciate guidance on my 70 (12/69) Metuchen car.
Thank you
70 Mach 1 428 CJ with AC and C6
3.25 with Truetrac limited slip
Metuchen
December 30 1969
Yellow
Re: 70 Metuchen Rocker Panel/Rear Blackout
« Reply #1 on: July 17, 2015, 09:04:33 PM »
Hope the NOS one you got the color from was the same color as originally used. Not unusual for service replacements to be different tints and tones
As for the black out detail behind the side and rear molding here is what I found in my files
Hope it helps
Basically, like other plants, the areas of concern (on the sides) were between the front fender and door/rocker gap and between the quarter panel section, the rocker panel section and the rear door edge.
At the rear the gap between the taillight cover/clad and the taillights, gas cap and around the trunk lock.
Not as many nice pictures of NJ cars since they tended not to hold up well over the years but here you go
Appears the black out was sprayed on like the pinch weld black out. Pinch weld black out appears to have been applied wider/higher than we often see. There was on very early example that showed a slightly different pattern but that would likely not apply to your car given your build date
Quarter panel to rocker and door
Passenger side fender to door gap
Taillight panel - in the one example it appears the black has been polished or worn off where is was accessible
Hard to see but it appears that the area around the trunk lock is black out when comparing contrast and color
Example where it appears the shop of owner had started removing the black-out
Offline wjgrnp
« Reply #2 on: July 18, 2015, 08:12:38 PM »
Thanks Jeff
Greatly appreciated
Ward
Metuchen
December 30 1969
Yellow
Offline wjgrnp
« Reply #3 on: July 26, 2015, 09:50:17 PM »
Jeff
Was the door sill edge above the lower rocker panel also blacked out?
Ward
Metuchen
December 30 1969
Yellow
« Reply #4 on: July 26, 2015, 11:14:55 PM »
Jeff
Haven't seen that though Ford started installing a thin dark plastic piece (strip) behind the top edge of the rocker panel molding (between the rocker and the molding) to hid thus edge.  Not sure when they first started installing these at each plant but you should be able to find a thread that discusses this little detail
Offline wjgrnp
« Reply #5 on: July 27, 2015, 03:18:03 AM »
Jeff
Thanks for the information.
That will solve my problem perfectly.
Can anyone suggest a supplier?
Regards
Ward
Metuchen
December 30 1969
Yellow
Offline sah62
« Reply #6 on: July 27, 2015, 08:46:44 AM »
Jeff
Regards
Ward
My company (Muscle Car Research LLC) recently introduced an excellent reproduction of the 1970 rocker panel filler strips:
https://www.musclecarresearch.com/63101B62-1
NPD also sells a reproduction, but it isn't mine and it costs more. I haven't purchased one so I don't know about the quality.
https://www.npdlink.com/store/products/filler_door_opening_rocker_panel_pair-196382-1.html
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline wjgrnp
« Reply #7 on: July 27, 2015, 10:00:12 PM »
Thanks Scott
Ordered and dispatched
Regards
Ward
Metuchen
December 30 1969
Yellow
Offline sah62
« Reply #8 on: July 27, 2015, 10:11:47 PM »
Got it; thanks, and sorry about the shipping cost. The box is light but large.
Scott Hollenbeck
