Author Topic: Gun Blueing  (Read 6040 times)
Gun Blueing
« on: July 15, 2015, 01:20:53 PM »
     I would like to use the gun blueing process in lieu of the oil phosphate process on my 9/19/68 Metuchen; shock tower caps, the shock tower braces and perhaps down the road the hood hinges.  Perma blue sells a kit but the liquids are in 3oz. containers.  How much of this stuff is needed ?  Thanks, Brian
Re: Gun Blueing
« Reply #1 on: July 15, 2015, 01:59:27 PM »
If you choose to go that route the 3 oz. containers should be enough to do at least a couple pairs of caps.
Re: Gun Blueing
« Reply #2 on: July 16, 2015, 01:01:46 PM »
Thanks for the reply.  Brian
Offline Anghelrestorations
    • Anghel Restorations
Re: Gun Blueing
« Reply #3 on: July 16, 2015, 01:11:38 PM »
I'm not sure I would do the gun blueing vs the phosphate and oil on those pieces as visible as they are.  Doing that by hand on hood hinges not sure how good that can look.  I have only done that on smaller parts really.
Marcus Anghel
www.anghelrestorations.com
Re: Gun Blueing
« Reply #4 on: July 16, 2015, 03:08:07 PM »
OK and thanks for the caution.  I guess a re think is in order.  Brian
Re: Gun Blueing
« Reply #5 on: July 16, 2015, 06:39:15 PM »
I think you might be fine with the look of gun bluing  on those shock mounts. Have worked for me. Would give it a try (pretty cheap to do and easy to change) and see how it looks compared to the other P&O finishes in the engine  compartment.
I've also used it to touch up pieces that were P&O'ed  if the repair area is not too large
Wish I had know this was going to come up today - was at the shop and could have taken some side by side comparison pictures :(
Just me
Offline sportyworty
Re: Gun Blueing
« Reply #6 on: July 16, 2015, 09:04:01 PM »
Just go buy a jug of prep and etch (Phosphoric Acid) at Home Depot for 15.00 bucks
Drop them in a stainless pot at about 180 degrees for 20 min. Done then wipe them with some motor oil and let them sit for a day. I have been Browning, Blueing and phosphating  Zinc (GM)and Manganese (Ford)all week here.
Cold Blueing is not durable and provides almost zero rust prevention. Just be sure the parts are stripped clean first Brian.
« Last Edit: July 16, 2015, 09:12:28 PM by sportyworty »
Re: Gun Blueing
« Reply #7 on: July 17, 2015, 12:44:16 PM »
     Thanks Kerry.  Great suggestions.  So my next two questions are;  where to get something big enough to hold the 2' shock tower braces and is sand blasting the parts necessary ?  Brian
Offline sportyworty
Re: Gun Blueing
« Reply #8 on: July 17, 2015, 03:24:34 PM »
Welcome Brian :)
Restaurant supply store.
Chemically strip or wire wheel the steel parts unless you have glass bead a tumble capabilities.
Re: Gun Blueing
« Reply #9 on: July 17, 2015, 04:07:35 PM »
Berryman in the 5 gal with a basket:
http://www.berrymanproducts.com/products/carb-and-parts-cleaner/berryman-chem-dip-professional-parts-cleaner/
I always liked the results...makes easy work of tough to clean engine parts but a clean bucket can do "paintables" too! I like having 2 buckets, one for the really cruddy stuff and one for a final clean (or carbs)...then simply change in a new bucket regularly. Time is money too, this stuff saves a lot of time.
Hood hinges/latches, door latches, trunk latches...easy-peasey!
« Last Edit: July 17, 2015, 04:32:03 PM by 67gtasanjose »
Re: Gun Blueing
« Reply #10 on: July 17, 2015, 04:53:52 PM »
FYI the 2' shock tower braces are typically painted. Where your Metuchen braces un painted?
Re: Gun Blueing
« Reply #11 on: July 17, 2015, 06:17:04 PM »
They are currently painted and it seems they are correct.  Everything else listed is P & O.  Thanks,  Brian
« Last Edit: July 17, 2015, 08:30:18 PM by Brian Conway »
1967 eight barrel
  • Guest
Re: Gun Blueing
« Reply #12 on: October 04, 2015, 01:00:39 PM »
DO NOT WIRE WHEEL!!!!!  Bead blast them with a fine glass bead. If you use a wire wheel they will come out more of the blue gloss side.
Use the Birchwood-Casey de-greaser before you use the Perma-blue.  You can use the cotton swabs or a cotton cloth. Coat them and let them process for about five minutes, keeping them saturated with the perma-blue the entire time.
Take them in and rise and wash them in lukewarm water. Pat them off and spray the hell out of them with Birchwood-Casey Barricade. ( Used to be called Gun Sheath) and comes in a 10 oz spray can. I put them in a ziploc bag and left them until I am ready to use them.
Re: Gun Blueing
« Reply #13 on: October 04, 2015, 05:29:19 PM »
Have to disagree -  :)
Used a wire wheel for many years (brass brushes) and have been very happy with the final finish for bare stamped steel finishes such as rear shock plates
Just my experiences
Offline sportyworty
Re: Gun Blueing
« Reply #14 on: October 04, 2015, 07:13:33 PM »
+1
