Author Topic: Spray seam sealer - Early 65 Dearborn  (Read 1845 times)
Offline CW4macret
« on: July 06, 2015, 10:16:55 PM »
Well I got to play with my new seam sealer gun over the weekend.
« Last Edit: July 07, 2015, 04:45:13 PM by J_Speegle »
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline mach1one
Re: Spray seam sealer
« Reply #1 on: July 07, 2015, 12:01:42 AM »
what gun did you use? nice results
« Reply #2 on: July 07, 2015, 01:09:37 AM »
What car is this for? Don't recall the quarter panel to end cap panel seam being sealed or sprayed with sound deadener
Many years and plants didn't use spray seam sealer.
Pattern would be too narrow (it appears from the pictures) for some years and plants quarter panel sound deadener applications and wheel wells unless your going for a more generic and keep from any signs on where the passes are since that will make the narrow pattern stand out IMHO
Deduct for this all the time and unfortunately it stands out if you know your cars ;)
Might want to try a lower pressure You you don't get all the fine stuff around the edge and even refrigerate the product before you spray it
Offline CW4macret
« Reply #3 on: July 07, 2015, 06:21:27 AM »
64.5 D code Detroit car. Can you post pics of original or post link of pics?  I thought I had this right.  Oh well not to late to redo
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #4 on: July 07, 2015, 06:36:20 AM »
Yes, what gun is it? I need to do this. I assume the product is paintable?
« Reply #5 on: July 07, 2015, 05:28:25 PM »
Opps   ::)
[/quote]
Of course - unfortunately it looks like you're going to have to redo much of what you've accomplished. But this is the time to catch it - rather than after the car is painted or on the show field
Following were sampled from 5F07F127xxx. Just guessed on the time period since you didn't provide a month to focus on
- Wheel well sealant
- Trunk floor to forward floor panel seam
Trunk floor to taillight panel and rear bumper support
Taillight panel to rear cross member
From 5F07F151xxx - Wheel well sealant
Quarter panel sound deadener from 5F07F127xxx. Not applied heavy or close enough to identify spray pattern
Quarter panel sound deadener from 5F07F113xxx. Application allows for us to see three passes with the application gun/wand. Highlighted to illustrate
Appears that the only surface to be sprayed with sealant or sound deadener was the inner quarter panel surface.
Offline CW4macret
« Reply #6 on: July 07, 2015, 11:02:48 PM »
It is a  Lord Fusor gun with Lord Fusor HD Seam Sealer but the gun will take any brush-able seam sealer in a tube. I will try the 3M in a tube next
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
Offline CW4macret
Re: Spray seam sealer - Early 65 Dearborn
« Reply #7 on: July 07, 2015, 11:04:45 PM »
Thanks for the pictures Jeff. I will re-do and post results.
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
