Author Topic: disc rotor wear limit  (Read 15553 times)
Offline preaction
« on: July 04, 2015, 05:23:08 PM »
I looked in a 67 shop manual and it lists .810 as a rotor thickness but not a wear limit does anyone remember one and am I missing this info in the shop manual.
Re: disc rotor wear limit
« Reply #1 on: July 04, 2015, 07:00:13 PM »
You use the same rotors (C5ZZ-11002-B) as the 64-66 Mustangs do and the answer I got from my brake guy was no more than 0.010 inch, aka 0.800 inch. The 66 shop manual has it listed as a 0.002 inch "runout" which is supposed to be the same as wear. There are too many variables not specified in the shop manual. As your brake shop for their opinion.
Offline WT8095
  • Dave Z.
« Reply #2 on: July 04, 2015, 08:17:55 PM »
The '67 shop manual also contains the following, but the diagram doesn't make sense. Dimension "A" is listed as "maximum" - seems like it should be a minimum. And dimensions "A" & "B" combined would equal over 1.5 inches - does not correspond to the .810" dimension listed on the specs page. Weird.
Dave Z.
Offline preaction
« Reply #3 on: July 05, 2015, 09:17:58 AM »
Thank you, it seems odd that theirs a wear value for the drums and not the rotors.
« Reply #4 on: July 05, 2015, 09:34:39 AM »
is the minimum thickness not cast into the inside rotor surface??
« Reply #5 on: July 05, 2015, 10:25:16 AM »
I looked into this last year and believe I found the answer over on VMF site. I wish I could recall exactly what it was but think it was like .780", not much room from a stock rotor to be turned more than say one time for runout,(warp) if it's grooved, chances are it is no good.
Offline Smokey 15
« Reply #6 on: July 05, 2015, 11:18:33 AM »
 What bothers me is that, with most of the crap repop rotors coming from China, many of them have to be trued in a brake lathe before you can use them because the runout is so poor. It used to be that all you had to do was spray them with brake clean, grease and install the bearings and put them on the car.
Offline preaction
« Reply #7 on: July 05, 2015, 11:44:39 AM »
Can anyone identify this rotor, I know the repops are close but different.
« Reply #8 on: July 05, 2015, 12:58:42 PM »
 author=67gtasanjose
  Pretty good memory.   Brian
« Last Edit: July 05, 2015, 02:19:50 PM by Brian Conway »
Offline Toploader
« Reply #9 on: July 05, 2015, 03:39:55 PM »
After a couple of hard brakings you'll have to true them once again  ;D
76A-Y-D2-13H-72-6-6
Offline Smokey 15
« Reply #10 on: July 05, 2015, 03:51:07 PM »
That's true!
Offline preaction
« Reply #11 on: July 05, 2015, 06:49:23 PM »
Thanks Brian it was hard for me to see the inside of the rotor with it on the car.
« Reply #12 on: July 05, 2015, 08:24:46 PM »
it is at the very least older because I it is 2 piece instead of the current one piece aftermarket.
Offline sgl66
« Reply #13 on: July 05, 2015, 11:48:00 PM »
Who makes the best repop rotors these days? Checked mine today and they are at .775
or, Brian maybe you want to see those rotors go to good use on my car?
« Reply #14 on: July 06, 2015, 01:27:51 PM »
unfortunityly none are the 2 piece style . The one piece is easily distinguished as after market and non original.
