Author Topic: Cowl to Inner Fender Brace Tubes  (Read 1427 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: May 09, 2010, 01:10:37 PM »
On my 66 convt...  What hardware is supposed to be used at the front end of the two diagonal tube braces that go from the cowl to the R and L inner fenders.  One was off the car and the other had an original bolt with star washer frm the inside of the engine compartment, but inside the wheelwell it had A SQUARE THREADED PLATE about1.75" square.  I don't think this is correct.  Well I guess I found the answer...My Osborne book shows the square plate to be correct.  Does anyone have one, I'm missing one?
P/N C5ZB-16D112
« Last Edit: May 09, 2010, 01:15:29 PM by bryancobb »
66 Metuch Conv
Nightmist, Std Blu Int
Re: Cowl to Inner Fender Brace Tubes
« Reply #1 on: May 09, 2010, 10:50:39 PM »
If you can't find someone that has one, would be relatively easy to fabricate since you have one to use as a pattern.
