Author Topic: Negative Battery Cable for 84 GT 5.0 ??  (Read 2781 times)
Offline hopeto
« on: May 09, 2010, 10:48:43 AM »
Hi guys, I'm new to the forum and I'm in need of a NOS negative battery cable for my 84 GT Convertible 5.0. It's marked "D9ZF 14301 CB SXN Motorcraft" in several places down the cable. I ordered this car new and it has 1800 miles. Any leads on where to locate a new cable would be appreciated. Thanks!
Original one owner 84 GT Convertible with 1800 miles. 65 Silver Smoke Gray K Code GT Coupe - 65 Cyclone - 67 Vintage Burgundy K Code GT Coupe.  1970 Calypso Corral Boss 302 - 2012 Yellow Blaze Boss 302.
Re: Negative Battery Cable for 84 GT 5.0 ??
« Reply #1 on: May 11, 2010, 08:42:18 AM »
Have you checked with your local Ford dealer?  Of course, like the older generations, you'll have to be careful of updated parts with old part numbers.
Otherwise, you'll probably have to settle for a good used original.
Offline roadrunner
« Reply #2 on: May 11, 2010, 10:25:13 PM »
You can check your Ford dealer, but they probably won't be able to find one. They usually only deal with service replacement parts which are not the same even if the part number is. Try Mustangs Unlimited or 5.0 Restoration or some of the other reputable vendors. You may have to recondition what you have.
