Author Topic: Neutral Safety Switch Harness Repair  (Read 786 times)
Offline 66RavenGTCoupe
« on: June 30, 2015, 03:23:54 AM »
Just doing a quick repair on this until I can get a clean original. The PO did not heat shrink it but I failed to keep in mind which bullet connector went where.  :-[ (See connectors circled in image) Does it matter which one is male and which is female?
Thanks.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Online midlife
Re: Neutral Safety Switch Harness Repair
« Reply #1 on: June 30, 2015, 07:48:02 AM »
It doesn't matter which is which, but the male has to plug into the female coming from the fusebox and the female has to go to the tail-light harness.  Remember: female connectors are always hot when energized.
« Reply #2 on: June 30, 2015, 09:28:08 AM »
I was hoping you would reply Midlife. You helped me once in the past with a sheared back up light wire causing a short because it was rubbing against the inner rear qtr panel where a grommet was missing. I would never have found it if it was not for you so thanks again. So it does not matter which way I connect the male/female connectors up as long as they are connected to the right things once done - got it.
Thanks again.
Dan.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
