Author Topic: 390 saga continues BACKFIRES  (Read 14295 times)
Offline Toploader
Re: 390 saga continues BACKFIRES
« Reply #45 on: November 07, 2015, 02:51:15 PM »
Remember that the composition of gas has changed a lot since the late 60's/early 70's.
76A-Y-D2-13H-72-6-6
1967 eight barrel
  • Guest
« Reply #46 on: December 08, 2015, 01:13:04 AM »
I found 16 NOS BF32 plugs. I did used them and noted they fouled quickly because the vehicle was only being moved inside and out of the garage and shut down. I used to take it around the block to try and allow it to come up to temperature before putting it away. A couple whiny neighbors bitched because the front end wasn't on the vehicle. Now that it's back from paint I am reassembling the vehicle. I went through the engine and re-cammed it being the duration was too short and it was coming on too fast. The rich idle mixture kept the rings from seating the first time. I am trying to find someone in the Dallas area that has a stand at home to break it in on before putting the new engine in the vehicle.
Offline somethingspecial
  • 1968 GT/CS Registrar mikej@bigbytes.com
« Reply #47 on: January 26, 2016, 12:28:28 PM »
Unless I missed it, have you replaced the old fuel after sitting for three years.  My 390GT had the same problem, fouling plugs, back firing, etc.  I drained the fuel, flushed the line, refreshed the carb and now it runs great.  I checked all the things you mentioned and finally went to the old fuel, which was the culprit.  Mike
Your friendly neighborhood 1968 GT/CS Registrar
Offline Smokey 15
« Reply #48 on: January 27, 2016, 08:31:08 PM »
 Good point. When I start a vehicle that has been sitting a long time, I unhook and plug the fuel line from the tank. I then run a fuel line into a 5 gallon can of fresh fuel.
« Reply #49 on: February 11, 2016, 12:05:25 PM »
Any Update? What did you find out about the fuel?  Just curious. Mike
1967 eight barrel
  • Guest
« Reply #50 on: February 11, 2016, 02:14:39 PM »
Information that would have been helpful from the get-go. Anyone knows that fuel after three years degrades and is essentially varnish at that point. The only fuel I have even seen that may survive that long is race gas.
