Author Topic: original '67 289(4v) automatic vacuum advance  (Read 980 times)
Offline socalgt
« on: June 29, 2015, 09:33:32 PM »
Was the original vacuum advance one piece...or was there a separate piece with the small fitting for the hose screwed into the body?  Also, am I correct that the vacuum advance tube was rubber in '67, as opposed to the '66 steel one?
« Last Edit: June 29, 2015, 11:26:57 PM by socalgt »
Re: original '67 289(4v) automatic vacuum advance
« Reply #1 on: June 30, 2015, 12:01:57 AM »
Two piece vacuum advance pod including the screw on nipple fitting. Rubber  vacuum advance hose in 67.
Offline socalgt
« Reply #2 on: June 30, 2015, 12:53:20 AM »
Thanks....
« Reply #3 on: June 30, 2015, 04:20:33 PM »
Just to illustrate what Bob posted -  NOS example though the dist lead has been removed. Not a later service replacement or rebuilt unit - boxed in 1968
To all: DON"T COPY THE PAINT MARKS it may not be correct for your application ;)
Offline socalgt
« Reply #4 on: June 30, 2015, 06:31:35 PM »
Nice pic.....I can see with the different finish on the metal the piece that screws into the main body...
                                                Thanks...
