Author Topic: 66 am 8 track and bezel installation diagram?  (Read 650 times)
Offline 7Lscjracer
« on: June 28, 2015, 02:32:58 PM »
Anybody have a legible picture of this?
Specifically I need to know what combination of nuts and internal tooth washers are required in what order to install the unit and bezel thanks.
Bought May '81, sold Sept '20
Re: 66 am 8 track and bezel installation diagram?
« Reply #1 on: June 28, 2015, 04:10:41 PM »
You have the assembly information in the drawings. In the library section of this forum under "Mustang Hardware Spreadsheets, 64-66 -" you will find a spreadsheet sorted by application (MHW64-66AP01.xls) that has the descriptive technical information you need.
Offline 7Lscjracer
« Reply #2 on: June 28, 2015, 05:18:06 PM »
Thanks I see 2 internal tooth washers and 2 nuts called out, so they'd simply have to install between the bezel and chrome knobs then.
Just to clarify, my question was only to do with what goes over the left and right shafts - how many and in what order.
I had envisioned more than one washer and nut per shaft is all, and I couldn't make out that fuzzy, small diagram pic.
