Author Topic: dimmer switch retainer  (Read 3350 times)
Offline Stangly
  • Gold Level Subscriber
« on: June 24, 2015, 10:29:02 PM »
Anybody know where I can find the little black pad (dimmer switch retainer) hat goes under the dimmer switch
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Offline D0ZZ70MACH
  • 1970 Mach 1 Dearborn 11/10/1969
Re: dimmer switch retainer
« Reply #1 on: June 28, 2015, 10:18:27 PM »
If I'm correctly understanding what you are searching for, there is one up for sale on ebay right now (ebay item#121690821245).
http://www.ebay.com/itm/1967-1968-1969-1970-Mustang-Shelby-Mach1-Cougar-Headlight-Dimmer-Switch-Bracket-/121690821245?hash=item1c5556927d&vxp=mtr
Hope it helps!!
Offline Smokey 15
« Reply #2 on: June 28, 2015, 10:32:23 PM »
 That would be easy to fabricate, if they are hard to find and in any demand.
Offline Stangly
« Reply #3 on: June 29, 2015, 08:59:17 AM »
That would be the part unfortunately I didn't get there in time. Thanks for the help guys, I can't believe nobody makes this thing.
68 Coupe J-Code
2001 V6 Laser Red
« Reply #4 on: June 29, 2015, 10:02:14 AM »
a VERY universal part on basically evey 60-70's (maybe longer) Ford product with a floor dimmer switch . You just need to ask the right people or scrounge around a boneyard. Pickup trucks are usually sitting around somewhere in your own neighborhood junkyard ;)
Offline drummingrocks
« Reply #5 on: June 29, 2015, 11:41:24 AM »
I've looked at the pictures, but I can't remember this part.  What exactly does it do?  Bolts to the floorpan to retain the dimmer switch?  I thought the dimmer switch bolted directly to the floorpan like on a '65-66?
« Reply #6 on: June 29, 2015, 11:59:00 AM »
It's a plastic wire separator, C7AB-14A163-A. Ford calls it a "retainer" which you could say it does for the wires.
Offline GT500KR
  • Charlie Ping
« Reply #7 on: June 29, 2015, 12:51:30 PM »
Put simply, it holds the plug against the switch, and is held firmly in place once the switch is bolted to the floor. Keeps the plug from working loose.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
« Reply #8 on: June 29, 2015, 03:57:13 PM »
Now it becomes clear.
« Reply #9 on: June 29, 2015, 04:47:17 PM »
...and even clearer.  Brian
Offline D0ZZ70MACH
« Reply #10 on: August 21, 2015, 08:33:15 PM »
Hello Stangly.  If you're still looking, there's one up on ebay item#262013317129.
Good luck!!
