Author Topic: 67 starter solenoid pics  (Read 2764 times)
Offline preaction
« on: June 24, 2015, 08:27:10 PM »
This is the one from the car as I got it and IIRC it was sticking  from lack of use, the AMK was an A2
« Last Edit: June 24, 2015, 08:53:21 PM by carlite65 »
Re: 67 starter solenoid pics
« Reply #1 on: June 25, 2015, 10:22:18 PM »
In a very rare cases you can also find the plastic bottom (different supplier using the -A2 marking) solenoids used during 67 or even a C6 (hard to find) marked on during the early months
As you can see the plastic bottom one was produced by a different supplier which may in turn reflect the assembly plant they can be found on (cars from that plant on a very rare bases IMHO). It also uses a different finish in the mounting base
If you check the bottom of your original you should find a date stamped them or metal bottom ones as shown below
A shot of another one like yours - have studied these for a long tiem
« Last Edit: April 24, 2016, 07:28:55 PM by J_Speegle »
« Reply #2 on: June 26, 2015, 06:14:27 AM »
Jeff, the number and letters stamping on the bottom plate, would that be a date code?
If they are date codes,
7DC decodes to: <fill in the blank>  (my stab at it: 7=1967, D=April, C=third week)
7HA decodes to: <fill in the blank>  (my stab at it: 7=1967, H=August, A=first week)
Richard
« Last Edit: June 26, 2015, 06:22:54 AM by 67gtasanjose »
« Reply #3 on: June 26, 2015, 02:25:02 PM »
Yes as mentioned above. Not sure of the third digit at the moment - will check to see if I have an records of the last letter being greater than "D" If so then it would decode differently for the last part
« Reply #4 on: June 26, 2015, 02:32:17 PM »
If the third character actually does represent the week, it seems there would also be a 5th week, or letter "E" possible (most some of the time~edit per Jim's next comment below) or does that somehow roll into the following month as the "first week"?
« Last Edit: June 26, 2015, 03:25:04 PM by 67gtasanjose »
« Reply #5 on: June 26, 2015, 03:18:28 PM »
Somewhere I read that the production week started on a Monday. A 5 week month would have a maximum of three working days in week 5 so parts marked "E" would be relatively rare.
« Reply #6 on: June 26, 2015, 04:22:27 PM »
Would guess that it might be a general standard though might differ from manufacture to manufacture.
Only research and data will help us figure this out - I expect  :)
« Reply #7 on: June 26, 2015, 05:58:44 PM »
I did a date analysis on three years, 65, 66 and 67, for working days in a possible fifth week.
1965 had four months with fifth work week days: March - 3, May - 1, August - 2, November - 2.
1966 had four months with fifth work week days: January - 1, May - 2, August - 3, October - 1.
1967 had three months with fifth work week days: May - 3, July - 1, October - 2.
I did not consider holidays, weekends or plant closures. The number of days is maximum, no more than 3 in any fifth week is possible no matter what day of the work week is used as a starting point. There will be a maximum of 4 or minimum or 3 fifth work weeks in any given year.
