Join us on Facebook: Search for 'ConcoursMustang' Private group!https://www.facebook.com/groups/concoursmustang/Indiana SAAC Fall Classic , French Lick, IN Oct 11-12http://www.insaac.org/SAAC National-Sanctioned Concours Event
I have a 1967 GTA S Code Fastback San Jose early December Build. I'm assembling my 390 engine and trying to work out all the kinks. I ran across several setbacks assembling it, but finally figured out bracket locations. I'm still have a space issue on the power steering bracket. Also, is the cast smog cast smog pump bracket supposed to be bare cast? Here are some pictures of the motor. There are missing smog hoses and fittings. Please pick apart it and let me know if anything is missing or if I could do something better. Thanks Travis
On the thermactor pump adjusting bolt, I cannot see clearly if the washer on the adjuster slide bolt is the funny-looking one with the tabs that run inside the slotted hole. I'm not sure how to describe it clearly but it isn't just a flat washer. In the pictures, it looks like it COULD be the correct one, but I cannot see it clearly.
........the cast smog bracket is engine color. ...........
J_Speegle, - Face (surface facing forward once installed) of the rear cast bod was natural not painted. Appears in #2 and #5 sections are blackNot sure what you are talking about.
So, I need to paint the smog cast bracket blue? are the bolts for the cast bracket need to be painted blue?
April 28 Build, Dearborn.
Preaction, I found the hose on EBay. The seller is Mustang Ranch in Fresno Ca.
Hi Travis, I have this same engine but with air also. The thermactor system is complete and operating with vanes in the pump let me know if can help. Where did you get the hose from the air filter to air pump, is it new ?
Is there any decals that go on the carb air cleaner for this engine ?
