Author Topic: 65 - 289 -Fuel Pump Bolts Head Markings  (Read 2291 times)
Offline sanluis09
« on: June 19, 2015, 07:42:01 PM »
Hi everyone,
Do someone knows what are the head markings for the original fuel pump bolts for the 65 Mustang, 289 ? Build date before April, 1965.
Thank you,
sanluis09
« Last Edit: June 22, 2015, 08:33:39 PM by J_Speegle »
1965 WW Hardtop, 289-2V, 3-speed manual transmission. Unrestored. Assembled in Mexico on the time frame of: Oct 64-Feb 65.
Re: Fuel Pump Bolts Head Markings
« Reply #1 on: June 19, 2015, 08:19:31 PM »
They should have a 3/16 inch tall "R" in the center of two circles. What I've found is p/n 359081-S8, 3/8-16X1 3/8 bolt with a quad ribbed washer. It is not available from AMK.
« Reply #2 on: June 19, 2015, 08:21:34 PM »
+1. They were used on other years and different engine sizes as well so chances of sourcing some are good.
Offline sanluis09
« Reply #3 on: June 20, 2015, 08:44:18 PM »
Thank you for your replies. If someone has one of them please let me know, as I'm interested.
Regards
sanluis09
Offline suskeenwiske
  • 214-347-3628
« Reply #4 on: June 24, 2015, 01:07:35 AM »
Regards
sanluis09
I have a box full of old Bolts...I'll look and let you know if I have one or not.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline sanluis09
Re: 65 - 289 -Fuel Pump Bolts Head Markings
« Reply #5 on: June 24, 2015, 09:41:56 PM »
Thank you very much Ray,
I appreciate your confirmation.
Regards
sanluis09
  • 214-347-3628
« Reply #6 on: July 24, 2015, 04:03:28 PM »
This appears to match your description perfectly. Is this the correct Bolt?
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #7 on: July 24, 2015, 04:52:02 PM »
Looks like the one
Offline Richard P.
« Reply #8 on: July 24, 2015, 06:19:57 PM »
Virginia Classic Mustang sells fuel pump bolts for 1965. I don't know if they are the same as the one pictured.
Offline sanluis09
« Reply #9 on: July 24, 2015, 06:35:17 PM »
Ray
Hi Ray,
 ;D Absolutely is the right one! I'll send you a PM.
Thank you again!
Regards
sanluis09
  • 214-347-3628
« Reply #10 on: July 24, 2015, 08:34:29 PM »
Excellent! I removed this one from a 65' C-Code Coupe I restored 15-16 years ago. Been in a box, along with a few hundred other bolts ever since.
Glad to be of help.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
