Author Topic: '67 289 oil dipstick tube  (Read 1163 times)
Offline socalgt
« on: June 19, 2015, 08:56:04 AM »
Is the mounting tab on the dipstick bent 90 degrees where it bolts to the block....or flat...if the coil is mounted with the same bolt, I'm assuming  the latter.
« Last Edit: June 19, 2015, 08:58:51 AM by socalgt »
Re: '67 289 oil dipstick tube
« Reply #1 on: June 19, 2015, 09:14:02 AM »
... I'm assuming  the latter.
I believe you to be correct in your assumption. The 2nd one sure looks like mine.
Offline Hipo giddyup
« Reply #2 on: June 19, 2015, 11:22:10 AM »
I have seen the bent tab dipstick tube on 68' models including Falcon, Fairlane,etc..
