Author Topic: 1967 sway bar to frame brackets. Black, Phos, Silver Cad, Phosphate?  (Read 1657 times)
1967 eight barrel
  • Guest
I wasn't sure what the GT 15/16 bar brackets should be color wise.
Re: 1967 sway bar to frame brackets. Black, Phos, Silver Cad, Phosphate?
« Reply #1 on: June 18, 2015, 11:19:38 AM »
The 15/16 brackets did not automatically come on the GT Mustang as your post seems to imply (for others reading) . GT350/GT500 yes. The special bar that the brackets fit came on competition suspension equipped cars. Regardless they were bare steel . Scott Fuller Reproductions sells a excellent repro and his pictures on his site depict perfectly how they should look when new.  I use T9 boeshield to preserve the proper look.
« Last Edit: June 18, 2015, 12:24:28 PM by Bob Gaines »
« Reply #2 on: June 18, 2015, 12:07:22 PM »
I think the question was about the brackets, not the bar itself.
« Reply #3 on: June 18, 2015, 12:21:55 PM »
Jim,I amended the post for clarity.The 15/16 brackets only fit the special 15/16 bar .The brackets (they) are bare steel. FYI the smaller brackets used on smaller bars are also bare steel from what I have seen also.
« Last Edit: June 18, 2015, 12:25:16 PM by Bob Gaines »
Offline gtamustang
  • CPM
« Reply #4 on: June 18, 2015, 12:46:14 PM »
+! for Bob. All sway bar to frame brackets are bare steel.
1967 eight barrel
  • Guest
« Reply #5 on: June 19, 2015, 07:16:57 AM »
I have a '67 500, so yes. It has the 15/16" comp sway bar. However, at some juncture they were replaced with poly units and the original brackets were gone. I picked up a used set, but they had some mild pitting. In a light silver it is going to show.
