Author Topic: Pittman Arm  (Read 2066 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Pittman Arm
« on: May 06, 2010, 10:19:00 AM »
66 C-Code Conv. Stock Steering.
Does the Pittman Arm mount onto the splined shaft, pointed straight ahead with the steering wheel centered?
Common sense would say yes.  I don't think the shop manual says?
66 Metuch Conv
Nightmist, Std Blu Int
Re: Pittman Arm
« Reply #1 on: May 06, 2010, 02:07:36 PM »
is it not 'keyed' that is having one spline wider than the rest??
Offline bryancobb
  • 2009 Ridn' Around
Re: Pittman Arm
« Reply #2 on: May 06, 2010, 02:31:30 PM »
I don't have it off right now but I was getting my ducks in a row for an alignment.  If it is keyed as you implied...
Then I can assume it's installed correctly.
If not I need to remove it and reinstall it.
Bryan
66 Metuch Conv
Re: Pittman Arm
« Reply #3 on: May 07, 2010, 09:53:13 PM »
Yes the splines are different in part of the shaft and arm to help with orientation
Of course the arm will go on upside down also ;)
