If you are asking about the foam that goes over the power steering return and cooler lines, I have a couple of images that may help. There is one picture I don't have on file, that you will need to see as it is just where the blue paint daub is, that is a space where a plastic clamp goes to secure the two lines together, and another portion of foam follows that up. There is a picture on Jack's website that shows the clamp if you are not familiar with them.http://www.deadnutson.com/catalog/item/4065497/4706481.htmIf I get a chance later, I will try and forward an image where the clamp is. Hope this helps.
got more plastic hose holders left & the foam hose protector wasn't on all cars depending onwhen built as its more of a later 69-70 thing . the pump foam is 9'' & cooler hose is2-5'' foam
Is this hose available or do I need to re-use the old stuff.Both of mine are the same length, about 6 1/8 long.BTW, my car is 5/15/69 dearborn buil;t and had/ has both .clip and foam.John
Mustangs Unlimited sells it.http://www.mustangsunlimited.com/search_sorted.asp?Keywords=9371P&x=39&y=10
