Author Topic: Disassemble toploader problem !!  (Read 1528 times)
Offline mhubert89
« on: June 09, 2015, 09:31:43 PM »
Hi !
I am restoring my 4 speed 68 ! I follow the shop manual to dissamble my toploader.. I remove the counter shaft, now i cant put the transmission in 3rd gear to remove the front fork !! Someone have a tips to remove it ?!
« Last Edit: June 11, 2015, 01:43:57 PM by carlite65 »
Mustang Fastback 1968
289, 4 speed
Offline mhubert89
Re: Dissamble toploader problem !!
« Reply #1 on: June 10, 2015, 09:11:37 AM »
nobody can help me to remove this bolt on the top of the fork without be in 3rd gear ???
289, 4 speed
Offline Mike_B_SVT
« Reply #2 on: June 10, 2015, 03:06:38 PM »
I thought you needed to loosen the forks and remove the shafts before you pulled the counter shaft?
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #3 on: June 11, 2015, 01:42:18 PM »
Offline Hipo giddyup
Re: Disassemble toploader problem !!
« Reply #4 on: June 18, 2015, 12:20:50 PM »
It's been years since I have rebuilt my toploader but I remember having to pull the shift lever studs out of the case before I could move the forks forward?? I think that might be the hang up, my 2 cents?? :-\
