Author Topic: 67 shortie power steering hoses  (Read 1368 times)
Offline mach1one
« on: June 07, 2015, 01:27:01 PM »
For a 67 SJ late may build 390 ps car was there a transition date from the thick ribbed shortie ps lines to the fine ribbed ones? A early/late thing? Thanks Lu
Re: 67 shortie power steering hoses
« Reply #1 on: June 07, 2015, 03:13:33 PM »
Lu ,from my observation the change happened in early 68 production. It was a early late thing for 68 production and not 67.
Offline mach1one
« Reply #2 on: June 07, 2015, 04:00:27 PM »
Thanks for the info. I have a set of factory thick ribbed hoses Ill send off a get plated. Still looking for a original BB 67 fan shroud if you gaaaat any leads Lu
« Reply #3 on: November 02, 2015, 08:05:02 AM »
So Mansfield's are NOT anything better than the typical early service replacements for use on a 67 Mustang, regardless the engine size?
Mansfields's will work as correct for later 68's up to about what cut-off date?
« Reply #4 on: November 02, 2015, 12:18:50 PM »
Those hoses are not typical at all. They appear to be the superior made blue dot repros. You can not buy a better appearing reproduction for the application.  They are most like the later 68-70 Shelby, 67-69 Mustang  assemblyline versions with the fine line ribs. the 67 and early 68 had 3 thick ribs. The service replacements went through a couple of evolved changes and do not look like assembly line. I think Ed Meyer has some of the early thick rib ones he had made up on a ebay auction right now.
« Last Edit: November 02, 2015, 12:21:55 PM by Bob Gaines »
