Author Topic: restoring a distributor: how to remove long bearing ??  (Read 1408 times)
Offline mhubert89
« on: June 02, 2015, 04:14:12 PM »
hi ,
i am restoring my distributor on my 289. I almost done , just need to remove the long bearing inside the distributor..did someone have a tip to remove it !?
thanks
Mustang Fastback 1968
289, 4 speed
Re: restoring a distributor: how to remove long bearing ??
« Reply #1 on: June 04, 2015, 09:17:47 PM »
Not sure if there are any tricks to it - going to require a press I believe. Never did one myself - always left that to the dist guy :)
Offline markb0729
  • South Jersey
« Reply #2 on: June 04, 2015, 11:52:48 PM »
I spoke to Dan Nolan at Mustang Barn regarding this very topic.  He rebuilds distributors (and has a working Sun machine) but said a DIY technique would be to use a cutting tool such as a small file to cut small channels in the sleeve and remove it in small sections.  I didn't get into asking him about installing the new bearing sleeve but I was under the impression that he has installed them.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
« Reply #3 on: June 05, 2015, 12:29:57 AM »
I have installed these before a couple of times (many years ago) I did use a press and I had used another distributor shaft as a pilot tool (not wishing to risk damaging/bending the shaft I intended to use)
Offline mhubert89
« Reply #4 on: June 05, 2015, 10:25:39 AM »
yes seen to be hard to remove ! over here i dont have a dist guy !! i tried to rebuilt a use one but i am stock to this bushing !!
289, 4 speed
