Author Topic: C6 Kick down lever & switch wiring clip  (Read 750 times)
Offline Angela
« on: May 30, 2015, 07:16:50 PM »
Does anyone have a picture or description of either of the following?
(1) the nut that holds the kick down lever to the transmission at the neutral safety switch. Is there supposed to be a lock washer & nut -OR- a serrated nut without a lock washer (see pic below)?
(2) For '67 C6, should there be a clip held to one of the two neutral safety switch mounting bolts, used to hold the wiring harness from the neutral safety switch? If yes, does anyone have a picture of how the clip and wiring are oriented? I don't see how this clip helps in the '67 C6 situation.
Offline Angela
Re: C6 Kick down lever & switch wiring clip
« Reply #1 on: May 31, 2015, 05:58:33 PM »
I haven't been able to find a picture of this exact application, yet all of the C6 mustang application pictures I've found show a lock washer and nut. Unless someone corrects me, for now I shall assume that's appropriate.
Offline gtamustang
  • CPM
« Reply #2 on: May 31, 2015, 06:22:48 PM »
Lock washer and nut is correct for the kick down lever. Serated nut is not correct.
I have seen the clip for the neutral safety switch wiring harness attached affixed by the front (closer to torque converter) bolt attached the safety switch to the transmission.
Regards,
Pete Morgan
