Author Topic: Remote mirror door panel toggle - which way is up?  (Read 1612 times)
Offline 7Lscjracer
« on: May 30, 2015, 03:52:45 PM »
Thought it was supposed to say top at one end on the back?
Why do I hate repros?
How hard would it be to etch "TOP" into the mold so it comes out embossed in the casting?
Just don't want to get the cables upside down
2 on top one on bottom or vice-versa?
Bought May '81, sold Sept '20
Offline suskeenwiske
  • 214-347-3628
Re: Remote mirror door panel toggle - which way is up?
« Reply #1 on: May 30, 2015, 08:33:11 PM »
Two on the Bottom, one on the Top.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline 7Lscjracer
« Reply #2 on: May 30, 2015, 10:25:46 PM »
Awesome Ray
I assume it's held to the door panel with a pair of #8 screw thread rectangular flat clips?
« Last Edit: May 31, 2015, 12:18:58 AM by 7Lscjracer »
  • 214-347-3628
« Reply #3 on: June 01, 2015, 11:10:35 AM »
Awesome Ray
I believe that is correct but not 100% sure.
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #4 on: June 01, 2015, 12:17:13 PM »
You might try the Library section of this forum. There is a post - Mustang Hardware Spreadsheet 64-66, that has two spreadsheets, one sorted by application and the other by part number. The spreadsheet sorted by application contains the information you need about hardware.
Offline rocket289k
« Reply #5 on: June 01, 2015, 12:27:01 PM »
+1 props and thanks to Jim once again because his spreadsheet is a helpful super resource
Offline 7Lscjracer
« Reply #6 on: June 23, 2015, 11:28:23 PM »
I checked your spreadsheet Jim and found the screws and nuts readily.
Excellent job and a very comprehensive resource.
#8 bolt thread spring nuts were called out, but I used #8 screw thread spring nuts with countersink phillips screws instead.
Bought a 40 pack assortment of #6,8,10,14 sizes that look like this
