Author Topic: Hood molding on the earlier 65 models.  (Read 2221 times)
Offline Stang Sixties
« on: May 29, 2015, 07:01:04 AM »
Hi everybody,
I have a question concerning hood moldings on the earlier 65 models.
Do you know since when that trim was added on the front of the hood ?
My car was built the 25 th september 1964 and, the hood seems
to be the original one and there is some little holes drilled on it to receive the molding.
But I have a doubt, because I also saw some stangs built in October 1964 without that part ??
Thank You for your help ! ;)
Franck
Offline Richard P.
Re: Hood molding on the earlier 65 models.
« Reply #1 on: May 29, 2015, 08:48:30 AM »
It is my understanding that the hood lip molding was introduced around March 1965 with the introduction of the 1965 GT Mustangs.
« Reply #2 on: May 30, 2015, 04:53:05 AM »
Thank You Richard for your answer !
Franck
Offline suskeenwiske
  • 214-347-3628
« Reply #3 on: May 30, 2015, 08:08:22 PM »
The Hood, original, on my current Dearborn project has the Trim Holes,(unused); estimated Build Date January 23 with Date Stamp of Jan 13.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #4 on: May 31, 2015, 01:51:40 PM »
Ray
Hello Ray,
It's interesting, the hood of my vehicule is in the same configuration .
I think I do not have to put this lip molding.
Thank You. :)
Franck
  • 214-347-3628
« Reply #5 on: June 01, 2015, 11:08:50 AM »
Hello Ray,
It's interesting, the hood of my vehicle is in the same configuration .
Thank You. :)
Franck
It was an option for certain '65's that I believe became standard on the '66 Mustangs, though I don't know if that was true for all '66 Models.
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #6 on: June 01, 2015, 12:21:21 PM »
The hood trim was standard as part of the GT option, and "may" have been available on special order. It was standard on all 66 Mustangs. Shelby was always an exception.
« Reply #7 on: June 05, 2015, 10:29:21 AM »
Hello Jim,
In my case, you think my car got that molding in it's past life ? it's possible ?
Or the trim holes were drilled on all mustang hoods ?
Thank You  :)
Franck
« Last Edit: June 05, 2015, 12:11:00 PM by DSO 90 »
« Reply #8 on: June 05, 2015, 06:13:55 PM »
The hood trim was standard as part of the GT option, and "may" have been available on special order. ........
Don't believe it would have been something that a dealer or factory would do under the "special order" system. Too much paperwork and hassle. At best case something that may/could have been done by the dealer after the car arrived at the dealership - after the part was available through the parts system. So after (by 30-60 days) after the GT option would have been available.  So don't see how an early 65 owner could make much of a case to include it as being "stock" or factory on one of those cars
Sort of the same principle we see applied with the rear slats and spoilers used on Boss 302's and so many Mach I owners like to add   ::)
« Reply #9 on: June 06, 2015, 05:55:54 AM »
Hi friends,
Thank You for your help,
I think the first owner added that part few month later the car came in France.
Yesterday, I saw holes under the hood and, they seem not correctly drilled with
the new trim molding.
I put some pictures in attached quote...
Thanks to all of you
Franck
