Author Topic: '67 289 A code igntion coil location(Metuchen built)  (Read 3817 times)
Offline socalgt
« on: May 28, 2015, 10:17:27 PM »
I've seen the coil mounted horizontally on the right side of the intake manifold....and vertically, on the right front of the engine.  Where was it mounted at the factory?
Re: '67 289 A code igntion coil location(Metuchen built)
« Reply #1 on: May 28, 2015, 10:32:36 PM »
You've likely been looking at cars that were "restored" or from other plants, options and time periods
Looks like its passenger side head for your application
7T01C119xxx
7T01C149xxx
7T02C199xxx
7T02C237xxx
« Reply #2 on: May 28, 2015, 10:52:43 PM »
A minor technicality is that if thermactor equipped, the coil would be mounted on the intake.  That said, a Metuchen built car with a Californian DSO, or a non Californian DSO but with the thermactor option, would be rare.  But I bet there was at least one built.  Always a safe bet 8)
In other words, what Jeff said...
Offline socalgt
« Reply #3 on: May 29, 2015, 12:22:52 AM »
Thanks....one(or more)pictures is worth 1,000 words.
« Reply #4 on: May 29, 2015, 05:20:03 AM »
I'ld bet that the NJ car built with a DSO was a non-Thermactor car.    But we're going to get way too far off thread chasing that rabbit/line of discussion  :o
Offline 68 GT
ignition coil location
« Reply #5 on: July 26, 2022, 04:38:16 AM »
For a 67 NJ car, 289, C4, non-AC, where is the ignition coil to be mounted? Does it get mounted to an intake manifold bolt on the drivers side? And what does the coil bracket look like? Mine is missing.
VIN 7T01C246XXX
Actual build date 5-11-67
VIN 8F01J208XXX
Actual build date 6-27-68
Re: ignition coil location
« Reply #6 on: July 26, 2022, 10:26:07 AM »
All of them from any plant were mounted to the intake bolt on the passenger side. This engine photo has a lot of problems but the coil location is typical.
« Last Edit: July 26, 2022, 10:31:54 AM by RoyceP »
« Reply #7 on: July 26, 2022, 10:37:59 AM »
There is a reproduction which is fairly accurate shape - wise but the originals were not painted, they were phosphate and oil finish. The part number is C4DZ-12043-A.
« Reply #8 on: July 26, 2022, 02:41:09 PM »
+1 on finish . For clarification 65/66 were typically painted black . 67-70 were typically phosphate and oil . All of course excluding occasional anomalies.
Offline 68 GT
« Reply #9 on: July 26, 2022, 02:55:02 PM »
Thank you for the information, picture and part number! I really appreciate it!👍
VIN 7T01C246XXX
VIN 8F01J208XXX
« Reply #10 on: July 26, 2022, 05:42:37 PM »
Picture you posted is of
Based on unrestore a 68. Appears that the poster was looking for 67 non-thermactor applications
Based on all the examples I have the original location would be a carry over from 66 and attached to the face of the passenger side head as shown in the earlier threads about the same subject. Used the words "67 Coil location" and it found them quickly
Will be merging this thread and one of those so I don't need to post a link  ;)
« Reply #11 on: July 26, 2022, 07:12:46 PM »
True - I don't know why I chose to picture a '68 289. The '67 of course normally mounts on the cylinder head on the passenger side in non - thermactor applications. If the car was to be sold in Arizona or California when new it would mount like a '68 - on the passenger side of the intake due to the requirement for thermactor in those states..
Offline Ralf
« Reply #12 on: August 10, 2022, 01:16:58 PM »
Late 66 on mine, none thermactor. SJ.
« Last Edit: August 10, 2022, 01:20:15 PM by Ralf »
« Reply #13 on: August 10, 2022, 04:56:40 PM »
I know that you are concerned with assemblyline originality based on your past posts. With that in mind I thought I would mention that the ID sticker on your coil was most typically placed long ways along the body of the coil up and over the coil bracket and not along the coil bracket like you currently have it. Also the alternator is a later production rebuilt unit as indicated by the metal stamped engineering number (post March of 1969 ).
« Reply #14 on: August 10, 2022, 11:55:20 PM »
For others viewing the wire ends/boots at the coil are incorrect. Just in case others are looking and thinking of copying  as well as things Bob mentioned and the bypass hose clamp as well as clamp and hose finish
