Author Topic: Oct 64 A Code SJ Engine paint/build sequence  (Read 4155 times)
Re: 289 Engine Painting Questions
« Reply #15 on: April 13, 2023, 03:55:46 PM »
What kind of sealant was used on the heater hose fitting?
I use the indian head shellac stuff.
« Reply #16 on: April 13, 2023, 10:16:40 PM »
Some of these details are illustrated and visible in the other sections of the site. In particular those areas with factory or period pictures of the car and engine assembly. One such example would be found in the - The Assembly Line - Discussions related to assembly line practices and observations - Members Only Viewing ? Sub-Assembly & Supply Plants
Thread title is - Early Small Block Product Test Pictures
Thread titled - 64 Cleveland Engine Plant V8 Oil Pressure Test Might help some though the pictures are not as nice or from as many angles
You also have evidence of a mask of sorts over the heater hose nipple at the water pump to go along with the other hose nipples and necks that were unpainted to help the hoses seal to the items
« Last Edit: April 13, 2023, 10:20:02 PM by J_Speegle »
Offline Countrysquire
    • Houston Vapor Blasting
« Reply #17 on: April 13, 2023, 10:19:36 PM »
Thanks Jeff. I remembered seeing those photos here in the past, but dang if I could remember where.
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
« Reply #18 on: April 13, 2023, 10:27:36 PM »
Yes the down side of having allot of reference material posted and available but would rather have that than not have stuff posted and shared :)
« Reply #19 on: April 13, 2023, 10:30:28 PM »
Also the downside of getting old and not being able to remember things!
Bobby Crumpley
MCA#20316
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
