Author Topic: 65-66 Fastback Rear Fold down Seat Latch Poll?  (Read 7477 times)
Re: 65-66 Fastback Rear Fold down Seat Latch Poll?
« Reply #15 on: May 28, 2015, 09:28:56 PM »
It's Oct 64, a 65 Mustang. They used brackets (just a reminder -  ;)), but it's still a point to consider.
Worth a shot if the problem is the seat not going back far enough for contact
Remove the bumpers or the brackets would be my guess to test
Offline ChrisV289
« Reply #16 on: May 28, 2015, 10:22:13 PM »
Don't know if this helps but here is the position of my bolts when I was taking it apart.  Can these be adjusted anymore on yours?
2009 V6 Mustang Coupe
Offline DKutz
« Reply #17 on: May 28, 2015, 11:42:36 PM »
They are as far back as I can get it without hitting the back panel..
« Reply #18 on: May 29, 2015, 12:31:16 AM »
Not the greatest but
The rear edge of the seat does not look parallel to the trap door. There was another picture that hinted at the same non-parallel mounting, showing the RH side is forward. Maybe the LH side needs to go forward to straighten the seat out. On the two current Fastbacks I have (a 65 and a 66), neither seats fit well in the front with the seat down.
It took a while (I have a lot of pictures to flip thru), but here's a sketch I made of the bracket's location for a friend that "adapted" a 66 fixed rear section to be used in his 65 Fastback. Both sides need to be the same.
« Last Edit: May 29, 2015, 01:57:55 AM by jwc66k »
Offline DKutz
« Reply #19 on: May 30, 2015, 02:17:24 AM »
Must be an optical illusion, it's straight I checked today
