Author Topic: This can't be right. Can it???  (Read 4830 times)
Offline Bongoman
« on: May 02, 2010, 10:58:35 PM »
I've determined that I have a Ford Thompson power steering pump.  So it is supposed to be painted teal blue.  Okay, I can live with that.
(When I bought the car in 1982, the pump was Ford corporate blue.)
I bead blasted my pump and found two layers of a blue that is close to Ford corporate blue.  The older blue looked lighter than corporate but not off by a whole bunch.
I ordered the special teal-blue-for-power-steering-pumps rattle can from NPD.  I started to paint it and this is what it looks like.  Yikes!  It's what I'd call a dark metallic gun metal color with a slight hint of blue.
Questions:
(1) Does this look like the correct teal blue color? :-[
(2) Does anyone have a picture of a teal blue pump installed on a Ford engine?  (I'm having a hard time visualizing it next to a blue Ford valve cover.)
(3) Is the pulley attached to the pump supposed to be painted teal blue or semigloss black?
Many thanks.
Bongoman
BongoMan
1970 Mustang Mach 1
351c2v
Serial no. 0R05H130405
Built 1/14/70 at San Jose
Re: This can't be right. Can it???
« Reply #1 on: May 04, 2010, 01:03:39 AM »
Questions:
It looks like the NPD color I got and used. A bit more blue than many of the pumps I've seen (I've seen slightly greener blue ones) but IMHO in the region of what could be produced with a non-exact formula than seems to change between batches
Pictures of three original cars - 67-69
No the pulley was not installed when the pump was painted. It would have been semi-gloss black and added later
Offline Bongoman
« Reply #2 on: May 04, 2010, 02:46:54 AM »
Thanks Jeff.  Even in your pictures the color seems to be different in each.   :-\
Another question:  In a 1970 San Jose car, would the p/s pump bracket be semigloss black?
BongoMan
1970 Mustang Mach 1
351c2v
Offline Bongoman
« Reply #3 on: May 04, 2010, 01:04:06 PM »
Wait.  I think I found the answer to my latest question.  The MCA judging rules indicate the p/s mounting bracket and spacer are to be natural aluminum.  (Rule 4. R.)
BongoMan
1970 Mustang Mach 1
351c2v
« Reply #4 on: May 04, 2010, 10:44:22 PM »
The aluminum bracket is natural - the steel adjusting part is semi-gloss black
Offline erwin
« Reply #5 on: May 17, 2011, 03:05:09 PM »
Are you sure the bracket is aluminium for a 1970 Mach 1 and not just for a Boss? Mine does stick to a magnet...
Greetz,
Erwin
« Reply #6 on: May 17, 2011, 07:47:18 PM »
Well - what engine does your car have?
Just being a Mach I does not tell us much  :)
Offline erwin
« Reply #7 on: May 17, 2011, 08:02:50 PM »
Ok sorry. It's a 351 C 4v from San Jose. Vin: 0R05M120587
Another question: What color do the shockmount-BOLTS have? Mine are painted black as are the shockmounts themselves.
Thanx!
Erwin
« Reply #8 on: May 17, 2011, 08:16:17 PM »
The small block and the 351C both brackets appear to be done in semi-gloss black
The upper carriage bolts that attach the shock mount to the shock tower or the bolts for the shock to the shock mount on the front ?
Offline erwin
« Reply #9 on: May 17, 2011, 08:25:46 PM »
Thanx!
The first. Shock mount to the shock tower (3 bolts).
« Reply #10 on: May 18, 2011, 04:53:27 PM »
Thanx!
Those are carriage bolts that typically have the  dark heated treated look
Offline erwin
« Reply #11 on: May 18, 2011, 04:56:02 PM »
So I should clean them instead of leaving them black painted?
« Reply #12 on: May 19, 2011, 02:14:58 PM »
Yes if your cleaning them with a paint remover - blasting or something like that will change the metal finish
