Author Topic: Need help: NJ built 1965 Mustang A code Undercarriage / Engine Bay  (Read 2201 times)
Offline RonsMustangs
I'd like to know if anyone has pictures of the undercarriage and engine bay of a 65 Coupe that was built in NJ that's been restored.
65 Mustang A Code, 4 spd, 4 brl,
Raven Black exterior
Red deluxe pony interior
NJ built
Again Thanks
Re: Need help: NJ built 1965 Mustang A code Undercarriage / Engine Bay
« Reply #1 on: May 26, 2015, 10:49:24 AM »
Hey Ron, what is the scheduled build date of the car?  (From the door plate)
« Reply #2 on: May 26, 2015, 10:57:31 AM »
I will look and have that answer to you by the end of the day
« Reply #3 on: May 27, 2015, 06:14:52 PM »
caspian65
1965
Metuchen, NJ
2 Door Hardtop
289 4v V8
2 Door Hardtop, Red Pony Interior
Raven Black
May 18, 1965
Richmond
3.00:1, Conventional
4-Speed Manual
« Reply #4 on: May 28, 2015, 01:18:53 AM »
Looks like red-oxide undercarriage at Metuchen around that time.
Has your car already been stripped to bare metal?  Always best to find original samples and color match for best representation.
« Reply #5 on: May 28, 2015, 01:26:37 PM »
not yet i wish i could find someone that has done one
Offline markb0729
  • South Jersey
« Reply #6 on: May 28, 2015, 02:30:27 PM »
The one thing I've learned is that d not assume a restored car was done correctly.  Look for some unrestored examples.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
« Reply #7 on: May 28, 2015, 03:00:39 PM »
Mark nicely put. I think i'm really just looking for something that looks close to correct. Just think My son is 4 by the time he's 16 and takes the car out a few time (you know the rest of the story) plus he'll one day own my 14 other mustangs
« Reply #8 on: May 28, 2015, 04:13:01 PM »
The "restored" wording is the reason for me not responding since I don't collect (on a regular basis) pictures or data from restored cars so can't help in that way.
For undercarriage - originally you have
- No sealer applied to the bottom side of the car to the bare metal.
- Next (normally) a strong deep reddish brown epoxy primer applied
- Typical overspray (like every other plant) from the exterior body color paint. More on the outer surfaces (leaving a small/slight shadow behind the pinch welds)  and panels that hang downward. Fading away as it gets closer to the center of the car. Original cars will typically have at least twice (or more)  as much overspray as you find on restored cars from my observation
- Over this you have the overspray from the engine compartment and front wheel well application of the black paint at the front of the floor boards. Alos along the sides (front wheel well to rear valance attachment point at the rear)  to a lesser degree normally than the body color
- Rocker to floor pan seam sealer is applied like the original. No sealer at seat belt anchor brackets. Can't recall at the moment if the trunk drops received a strip of sealer or not.
- Of course the body has been sitting on the dolly during the whole process producing the 8 bare spots on the frame rails (showing the original galvanized finishes on the metal surface as well as the four pass through attachment points in the interior and trunk area.
Not allot of good pictures are available of early NJ cars due to the poor conditions we find most original cars in :(
- Engine compartment black was applied to fully cover the engine compartment, the radiator support (front and rear) as well as the front wheel wells from approx rear splash shield attachment point (not installed at the time) to the other side - same point.
As you progress past the painting stage we should be able to help with specific details.
