Author Topic: Well Liner Spring - 66 San Jose  (Read 1791 times)
Offline Herman
« on: May 22, 2015, 07:45:46 PM »
Hi All
I have a 66 GT Convertible built in Oct 65,  while going my score sheet I had received a deduction for no Well Liner tension springs.  When I was researching this part I noticed there are couple of different types 1x set of Long tension springs and the other has both a Short & Long tension springs which is a cross over part of the 66 model year I believe.
Therefore, which set is the correct tension spring set I should use.
Herman
« Last Edit: May 27, 2015, 12:59:18 AM by Herman »
Washing, polishing and cleaning stuff some more in an attempt to retain that 'Golden nugget'
Offline NEFaurora
Re: Well Liner
« Reply #1 on: May 25, 2015, 07:06:11 PM »
Herman, You forgot to mention what plant your car was built....  What is the 2nd character on your VIN#?
:o)
Tony K.
MCA#70001
Re: Well Liner
« Reply #2 on: May 25, 2015, 08:30:40 PM »
Have pics of a low mileage early February Dearborn '66 convertible and it has the long springs.
Re: Well Liner
« Reply #3 on: May 25, 2015, 09:03:02 PM »
Looked at SJ reference pics and only could find a couple and they were long ones also, installed like the pic above.
Offline Herman
Re: Well Liner
« Reply #4 on: May 25, 2015, 09:14:05 PM »
Hi Charles
Thanks for the photo and the car was built in San Jose plant Oct 65'
Herman
Re: Well Liner Spring - 65 San Jose
« Reply #5 on: May 26, 2015, 07:41:46 PM »
Closest I have pictures of is from right after the first of the year.
6R08C181xxx
6R08C188xxx
« Reply #6 on: May 26, 2015, 09:42:02 PM »
Hey, wheel house seam protector with triangle at top, hmmm....    ;)
« Reply #7 on: May 27, 2015, 12:03:56 AM »
Offline 66RavenGTCoupe
Re: Well Liner Spring - 66 San Jose
« Reply #8 on: June 03, 2015, 05:07:35 PM »
Mine are missing altogether. Would anyone know which type would go into a Sept 64 built SJ car? Are the indtalled the in the same position?
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
