Author Topic: Differential paint detail  (Read 2320 times)
Offline wjgrnp
« on: May 22, 2015, 12:53:35 AM »
Hi
Would appreciate some guidance with the correct color for the Carrier Housing.
The shop has my Differential apart for repairs so I was going to freshen it up with a new coat of paint while it is on the bench.
Currently it is what looks to be red primer.
Ward
70 Mach 1 428 CJ with AC and C6
3.25 with Truetrac limited slip
Metuchen
December 30 1969
Yellow
Offline 69GT350H
Re: Differential paint detail
« Reply #1 on: May 22, 2015, 09:22:27 AM »
Mine appears to be...  rust, many years of road grime and a bit of leaked fluid. Guess I'll be detailing mine as well.
« Reply #2 on: May 25, 2015, 06:23:22 PM »
The case and pinion retainer were painted on all sides (individually) with a shinny (not that flat stuff) looking red oxide color epoxy primer sealer. More red than we often find on the floors of some cars some plants. So things like shims, bolt heads, washers .... were not painted as you might find on some "restored" cars
Each piece was then machined leaving a bare, shinny finish in that areas. The surfaces that were machined depend on what size rear end your car has Seeing that you listed that you have a 69 CJ (thanks) we can provide some guidance and here there ;)
Would rather post pictures of originals but with surface rust and age details are a little harder to make out clearly
With snubber bracket attached - 69 9 inch application
The machined surface in the round balance hole should be more pronounced. Maybe its the angle our I should have brightened it up more
Members - don't copy the paint marks - they likely are not correct for your car and application ;)
Note - Moving this thread to the General Driveline area since the detail applies across the years - 65-73
Offline wjgrnp
« Reply #3 on: May 25, 2015, 08:09:51 PM »
Thanks for all the help
Ward
Metuchen
December 30 1969
Yellow
