Author Topic: 70 mach 1 correct engine  (Read 5942 times)
Offline knightrides
« on: August 06, 2009, 10:09:00 PM »
 hey guys, new to the forum, I currently restoring a 70 mach 1 0f05h199202, built 6/11/1970, does anyone know which 351 (clever/windsor) this car was born with, I heard it could be whatever the dearborn plant had at the time.
Offline C5ZZKGT
  • Gold Level Subscriber
Re: 70 mach 1 correct engine
« Reply #1 on: August 07, 2009, 08:56:06 AM »
It has always been my feeling (at least back in the old days) that 1970s had a Cleveland 351......I also have heard that about what ever the plants had at the time thing, may be someone else has better info than I, but if it was mine as long as it had A 351 engine I would restore it that way espessely if its a Cleveland.....I really think the Cleveland is "more" correct for a 1970....
Offline fast68back
« Reply #2 on: August 07, 2009, 12:06:39 PM »
Wouldnt a Marti report tell you which motor is original to the car?
Offline Sluggo
  • Dark Overlord
« Reply #3 on: August 07, 2009, 06:59:58 PM »
Being built in June, I'm pretty confident in saying they would have been out of Windsors.
MCA 55330 | 69 Mach1 | 427 Stroker | 29 Model A Murray Town Car | 4 Banger
Offline knightrides
« Reply #4 on: August 07, 2009, 10:11:02 PM »
the matri report just said 351-2v, but doesn't give the plant name cleveland or windsor,  tring to get the car close to a concours driver. I do have a correct date coded cleveland  may 12 '70 as a date code. also have a windsor but it was built too early july of '68. I do know all of the M codes were clevelands in 70, but when I attend the shows I see alot of H code as windsors as 1970.
Offline Sluggo
  • Dark Overlord
« Reply #5 on: August 08, 2009, 01:00:37 AM »
So the Cleveland you have is not numbers matching? What was in the car when you got it?
Offline mach514
  • Silver Level Subscriber
« Reply #6 on: August 08, 2009, 11:07:01 AM »
I thought early on the two barrels were windsor motors, but by june of 70 you would think they would have burned through the inventory.
have you looked for the vin# on the block (thats if you think it might be the original block) drivers side back of block just below the head.
Offline C5ZZKGT
« Reply #7 on: August 09, 2009, 08:38:22 AM »
I was never aware of a VIN on Windsors or Clevelands.....
Offline mach514
« Reply #8 on: August 09, 2009, 08:38:05 PM »
I believe right at 1968 all cars had to have thier engines and tranny's stamped with a form of the cars VIN. I'm sure it's possible that some escaped but they were supposed to be thier.
Offline Sluggo
  • Dark Overlord
« Reply #9 on: August 09, 2009, 08:55:03 PM »
My 71 (351C) had the last 6 of the vin stamped on the pad on the back side of the block on left bank.
Both blocks I have for the 69 have stamps there too. Both windsors. The one in the car is a later model.
The one that is not in use is the right year but wrong vin.
Offline roadrunner
« Reply #10 on: August 16, 2009, 01:15:50 PM »
It is accepted that 70 Mustangs came equipped with 351 Cleveland engines, both 2v and 4v. H code =351-2v and M=351-4v. An early production 70 Mustang might have come with a Windsor engine, depending on which plant it was built at.
Offline SCJSTU
« Reply #11 on: December 06, 2009, 11:09:57 PM »
my Oct 69 built 70 convertible has a 351W 2V...H code car.
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
« Reply #12 on: December 08, 2009, 12:54:30 AM »
For others viewing - that would be a Dearborn built car ;)
Offline SCJSTU
« Reply #13 on: December 08, 2009, 07:27:05 AM »
You are correct Jeff...
