Author Topic: Engine 65 200 6 cylinder - What is black?  (Read 1413 times)
Offline Skyway65
  • Gold Level Subscriber
« on: May 01, 2010, 09:41:48 AM »
I just want to confirm what I think I already know.  Was the entire engine assembled before the black paint was applied?  The oil pan bolts are painted, threaded drain bolt is painted (on the right side of the block).  Finally, would the oil pressure sending unit be installed before or after engine paint?  I didn't see where the MCA rules addressed these specifically. As always-Thanks. (200 CID/'Jan 65)
« Last Edit: May 01, 2010, 06:44:43 PM by J_Speegle »
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Engine 65 200 6 cylinder - What is black?
« Reply #1 on: May 01, 2010, 07:23:40 PM »
The engine (in this case short the valve cover) was assembled with oil pan in place so yes the mounting bolts and washers would be painted along with the block and other items
Don't believe the oil sender was attached to the engine at the time it was painted
Offline Skyway65
« Reply #2 on: May 01, 2010, 11:53:00 PM »
Thanks for that Jeff.  Doing some detailing today and that is what I assumed, just wanted to be sure. ;)
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline NEFaurora
« Reply #3 on: May 26, 2010, 10:03:38 AM »
Gary, It looks like your vert is finally coming along! You should post some pics of it..
Tony K.
MCA#70001
